Vandals rattle canned my Rims
Old Oct 24, 2004 | 06:33 PM
Formula_racer's Avatar
Car: 1990 Pontiac Formula WS6
Engine: LB9 5.0 TPI
Transmission: T-5 Manual
Okay guys, I'm still kinda new to the site but I have a problem that I need some help with. The other morning I went out to my car and found that some Punk kids had spray painted all over the rims on my Formula. Has the nice WS-6 rims too......Bastards! Anyway, I was wondering if anyone knows of a good way to get paint off my rims. This way I can just pocket the insurance money and buy some Headers to fix my exhaust leak. Thanks for all your help guys!
Old Oct 24, 2004 | 06:51 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
for 10% i'll tell you
Old Oct 24, 2004 | 06:59 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
headers wont fix your exhaust leak unless the cast manifolds have a hole in them (doubtful). i am aware of your want to get them but just letting you know.
Old Oct 24, 2004 | 07:07 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Interesting.
Sorry to hear that man. If your rims had good clearcoat on them, you *should* be able to rub off the spraypaint by spraying brake cleaner on a rag and rubbing. Just use it sparyingly and it should work fine.
Good luck man, I know a little something about vandalism also....
Old Oct 24, 2004 | 07:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get them sandblasted.
Old Oct 24, 2004 | 07:12 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Don't use brake fluid, use lighter fluid. It's far less toxic to you and the clear coat. Once you get the paint off, make sure to wash the wheels.
GL
Old Oct 24, 2004 | 07:22 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Well they'd fix the leak if it was a manifold gasket. Obviously he'd use a new gasket and thus--fix the leak. I think like that. To lazy to fix somthing, just want to make it better.
Old Oct 24, 2004 | 07:36 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
why not wetsand and polish?
Old Oct 24, 2004 | 07:38 PM
CaysE's Avatar
I'm with Air_Adam. Get them sand- or bead-blasted and recleared. Just learn from TunedPort 335: vandalism is an excuse to make your car better. Those wheels will look crisper than ever.
Old Oct 24, 2004 | 07:45 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
spray paint im assuming, use a pressure washer itll blast that stuff right off. ussually spray paint doesnt stick to well to a surface that wasnt scuff sanded for adhesion.
Old Oct 24, 2004 | 10:31 PM
Engine: LB9 5.0 TPI
Sweet thanks guys. It was definitely spray paint. I'll try pressure washing first and if that doesn't work i guess it'll be on to brake/lighter fluid....... as for sandblasting, umm how so. Don't you do that if your gonna polish them up real nice? Will that work for the WS-6 rims though, I know they have that rippled/machine feel on the face of the rim and then painted between the spokes. But anyway, thanks for your help guys. I appreciate it!
Old Oct 24, 2004 | 10:59 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Clay Bar?
Old Oct 24, 2004 | 11:00 PM
Engine: LB9 5.0 TPI
clay bar.......... on rims.............would that actually work? Anyone ever done it
Old Oct 24, 2004 | 11:01 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I dunno My friend got spray paint on his paint (not overspray), and a claybar took it off.
Old Oct 24, 2004 | 11:06 PM
Engine: LB9 5.0 TPI
Aight, I know clay bars work awesome on paint. I wonder.......:shrug:
Old Oct 25, 2004 | 12:13 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
def dotn sandblast them, that is wayyyy unnessisary.
maybe even some real strong wheel cleaner. i detail cars full time at a dealer ship. we have some wheel cleaner there that smokes when u put it on wheels taht are real covered in brake dust, it works damn good and doesnt hurt the wheels at all. if there any places near u that do detailing stop by and talk to them, i bet for free theyd pull ur car in and try to clean it off.
id try the pressure washer first. i bought some pony wheels for my 91 LX mustang that had been spray painted, well i took the hose to them and the spray paint litterally blasted off, made a mess on my driveway but the original paint was MINT on the wheels, they look brand new again
the brake cleaner could harm the clear coat on the wheels, i wouldnt suggest it unless its ur last resort. i noticed that it will turn the clear a weird blue-ish color, not good, it will also make the clear coat really soft.
Old Oct 25, 2004 | 03:12 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
As long as your rims are in pretty good shape, ie; not much etching, chips, corrosion, the claybar should take it all off pretty easily. They are clearcoated you know.
Old Oct 25, 2004 | 10:17 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I wouldn't be surprised if the paint wont come off the rough surface inside the "spoke" area of the wheels. Only the face is machined smooth IIRC.
I'd try the lighter fluid.
Old Oct 25, 2004 | 07:20 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Basecoat reducer, go to a body shop and ask them for a little besecoat reducer, trust me, i know, i work at a body shop and use it all the time to clean up overspray on various items.
Old Oct 25, 2004 | 08:47 PM
Metal's Avatar
claybar.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
