need help polishing
Old Oct 29, 2004 | 10:58 PM
thirdgenner05's Avatar
Car: 89 t/a
need help polishing
alright Ive been sanding polishing and stripping my stock firebird crosslace wheels. Although they look better than they did I cant get the mirror finish that everyone else does. I did aircraft remover, that got all the clear coat gone, then I had A LOT of scratches. So I started with 400, then 400 wet, 800, 800 wet, 1500, 1500 wet. They arent mirror or "chrome" looking just a little shinier.... so what am I doing wrong, am I not spending enough time sanding or what? thanks yall
Old Oct 29, 2004 | 11:26 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you haven't polished yet. after sanding you need to hit em with a polish like eastwood sells or other sources "white rouge" and a powered buff. on a die grinder or bench grinder, drills are a little slow but could still work.
Old Oct 30, 2004 | 05:41 PM
Car: 89 t/a
I just used the mother's brand and hand did it for about 2-3 hours today, omg they look really good. Anyway I could just use a buffer for waxing on them with the mothers? would that do just as good?? thanks
Jason
Old Oct 30, 2004 | 09:50 PM
A88GTANotchback's Avatar
buy a buffer....liek you i tried by hand and the effort is rewarded.....do the power and watch the shine
Old Nov 6, 2012 | 06:37 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
Re: need help polishing
Would a dremel work to polish
Old Nov 7, 2012 | 01:06 AM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
got a pic of what they look like? If you said the wheels had A LOT of scratches, very good chance you didn't sand out those scratches well enough on your initial sanding pass. 400 grit actually removes very little material...used handsanding, even less.
Old Nov 7, 2012 | 09:52 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Sand to 400 wet only, then hit with emery, tripoli, then white rouge used on a drill with a pad or dremel or whatever, then use your mothers.
Old Nov 7, 2012 | 11:20 AM
89RAG's Avatar
Car: 89 IROC-Z CONVERTIBLE
Engine: 5.0L TPI
Nev-R-Dull works fantastic as well. just gotta have the time and beers to complete the job. look amazing when they're done. i used this product on my 2 line iroc wheels. they are like mirrors when they're clean!
Old Nov 21, 2012 | 12:36 PM
Jeffs82TA's Avatar
Buy an electric 5 inch orbital sander and a makita or similiar grinder. sand to 220 then hit with your grinder and buff pads with emery and tripoli and white compounds.
this is a lower a-arm and my halfshaft and upper a-arm. Of course partially done but I never exceeded 220grit. 400 grit is the maximum I would go, anything more and your sanding marks are to fine and trap compounds and will make the surface cloudy.
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
