will the 91 front bumper fit my 88 GTA
Old Dec 2, 2004 | 08:29 PM
fst2qtrmile's Avatar
Car: 1998 eclipse GSX
Engine: 4G63 2.0
Transmission: 5 speed
I like the 91 front bumpers on the trans ams and want to putone on my 88 trans am. Is it a simple bolt on???
Old Dec 2, 2004 | 08:30 PM
megaracerx's Avatar
again i'll say...search...lol
Old Dec 2, 2004 | 08:55 PM
Engine: 4G63 2.0
you tell me to search and i say is it a simple bolt on. people with an answer of yes or no please reply
Old Dec 2, 2004 | 09:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
strangely enough, the problem you might run into is with the headlights. the 91 bumper has no headlight pocket, so the earlier headlights with the black trim piece in that area might not be compatible with it. I'm not sure if you can just swap trim pieces or if you're looking at swapping the entire headlight assembly for a 91-92 version
Old Dec 3, 2004 | 02:40 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
You should search...and to answer you question yes and no. You'll also need the honeycomb impact bar behind the bumper. One more thing he's right about the headlights....you'll need to grind off the lower lip. The newer birds have different headlights so the bezel won't fit the old lights. However grinding the bottom lip isn't that big a deal and they'll close fine afterwards. Other than that yes it just bolts up.
Old Dec 3, 2004 | 06:47 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I think it's been almost 3 weeks since I posted this link...
https://www.thirdgen.org/techbb2/sho...hreadid=225794
Old Jan 6, 2005 | 11:04 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
i saw that someone mentioned grinding and certain things like modifying what you currently have. I would suggest yard hunting. I got lucky and had a nice 92 formula plop down right next to the 88 bird i was pulling parts from while i was at the junk yard recently. I pulled the headlight assemblies, bezels, fog lamps/turn lights, metal brace, and the reinforcement. The cover was destroyed and had camaro ground fx screwed in to the sides. such a shame...such bad taste.
Anyways my point is you need everything i mentioned above except the headlight assemblies. By that i mean the actual huge metal casing that the headlight goes into. You DO need the actual headlamp and its assembly. It all bolts up and takes less than an hour. I got all my parts for less than $30, including the headlamps and fog lights.
Finding a decent 91-92 bumper will be the hardest part. Hope this helps and i just realized this was sort of an old thread. Oh well, if your still stuck ill post a pic of all the parts you need unattached to the car so you can easily see.
Old Jan 9, 2005 | 05:22 PM
SC82TA's Avatar
Grinding the lip is easier than swapping out all the headlight innards though and its free. You can put those $30 into something else. If you want to make it look better just do a good job of grinding then use some sand paper to smooth it out and shoot it with a few coats of flat bumper black or something. Should look like it came like that.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
