Tires...How Wide Can You Go?
Old Dec 4, 2004 | 04:50 PM
klumb15's Avatar
I was just wondering how wide of tires you can run on the back end of a stock(not tubbed) 3rd gen camaro? Can you run a 295 or perhaps bigger without rubbing? also does size of rim matter?
Old Dec 4, 2004 | 07:11 PM
megaracerx's Avatar
do a search....there a guy (not sure of his name) running 315's
Old Dec 4, 2004 | 07:37 PM
klumb15's Avatar
somebody has to have an answer........
Old Dec 4, 2004 | 07:41 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
285 40 17 bfg kdw 17x 10 rim
still has some room, but how wide do you really need to be?
it comes down to the look you want. i think this looks good, there is a point where big is to big.
Jeff
Old Dec 4, 2004 | 08:28 PM
klumb15's Avatar
well i don't want the tires stickin out or anything, its just i'm gonna buy new rims and and rear tires, so i mines as well go as big as i can go...they are gonna be either 16" or 15" rims....and 10 inches wide, I would like 16's but they are hard to find in 10" wide...so would you say 285 is the biggest you can go while still maintaining a reseanable level of style..
Old Dec 4, 2004 | 10:12 PM
JeffW's Avatar
Engine: 305 tpi LB9
well i like them but that is a 17" tire so for a 16 it would be diffrent. i also run a 245 45 17 frt so it has a good look to it.
i forget how the sizing works. since you going 16" you will have to find the size conversion.
Old Dec 4, 2004 | 10:13 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
you can go with a P295/50/R16 they look bad *** in my opinion just enough sidewall and real meaty in width, it should leave you sufficient room as well
Old Dec 4, 2004 | 10:59 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Look here and read to the end, this should answer your ??.(https://www.thirdgen.org/techbb2/sho...hreadid=230160)
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Vincent135
Sep 28, 2015 10:50 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
