1999 Camaro SS owner thinking of buying a 3rd Gen
Car: 1999 Camaro SS Convertible
Hey guys
I've always loved the look of the 3rd Gen Camaro, especially the 91-92 Z28's and the 87-90 IROC-Z's. I ended up buying a 1999 SS Convertible 6 Speed. I love the car and am thinking of starting a small Camaro collection.
My first thought was of a 1969 SS 396 Camaro, but those are crazy expensive. My next favorite is the 3rd Gen.
I'm getting ready to go back to Iraq soon (U.S. Army), but when I come home I'd like to buy one (Mush to the wife's dismay). I'm an avid manual trans fan also. I don't want the car to do a power build or for speed. I've got the LS1 for that. I want a nice, low mile, original Camaro Z-28 or IROC. I'm not going to get another convertible, one is enough.
What is the best year to get and what should I look out for? My next door neighbor has a 92 Camaro RS 25th Anniversary edition. He's had lots of electrical problems (VATTS), and it's pretty weak with the TBI 305. At a minimum I want a TPI 305. So what do you guys think?
Car: 2004 Pontiac GTO
Transmission: M12
If you plan on keeping the car stock but want decent speed, I would settle for nothing less than a L98 (350 TPI) or at the very least the LB9 (305 TPI).
I would suggest a 91 - 92 z28. IMO they look the best.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Well if you want a manual, you're not gonna get a 350 unless someone did a swap. I'd look for a 91-92 Z with an LB9 and 5-speed.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah, do a 89 to 92 Iroc or Z28 L98. should do the trick. all you need to have alittle kick in the pants with one of those is make sure it has the 3.27 rear (9-bolt in the 89-90 i think) or at least 3.23 or up in the 91-92 10-bolt rears and add a 2800 stall converter and shift kit. makes an enjoyable car.
Car: 1989 IROC-Z
Engine: 383 stroker
Originally posted by Aredross
Arent the 90-92 TPI's faster than the others?
Just thinking out loud
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
90-92 G92 305 tpi, good luck finding one, best bet will be a 91, dont think 90 iroc production was very high on em, 92 seems to be slim to none, figures seem to point at numbers most likely lower than 100, and not possible above 600, i have one of them, you've got 599 possible to search out.
Hardtop was required on them which should help you on a search looking through cars, 90-92 305 and disc brake its likely a G92, was only avail hardtop only manual and had discs.
Car: Pair of 92 Z28s
worst problem is that they didnt offer the 5 spd with the 350...
thats the only problem on my car is its not manual
but ill live with what i got cause i love the power it makes.
many people have droped the T-5 in the 350s and have had no problems...GM said it couldnt hold to the amount of torque the L98/350s made.
if u gotta have a manual definently go with a later iroc or 91-92 z28 LB9/5 spd. My plan sence i hate autos is to drop a T56 from a later model camaro next summer.
but ill live with what i got cause i love the power it makes.many people have droped the T-5 in the 350s and have had no problems...GM said it couldnt hold to the amount of torque the L98/350s made.
Engine: L98, Hemi 6.2
Originally posted by azvolfan
The '91-'92 Z28 305 TPI 5sp with dual exhaust was rated at 230hp. I think that will fit the bill nicely. As far as finding one, that may be tough.
Originally posted by megaracerx
but YOU dont need to worry about them anymore, do ya?
Car: 1991 Z28
Transmission: 4L60 automatic
there not that great...
ok ok...i admit...there are...but until i own one...my LG4 conquers all!
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
A 5 speed car is going to be much harder to find than an automatic, but they are out there. Are you up to do a conversion? I have swapped out automatics in 2 thirdgens, it is a very easy job ! I did mine first with no problems, other than the trans. finally let go. I now have a 6 speed in it....also an easy conversion. If you are game for doing the swap, there is plenty of information on this site alone to guide you through it.
Good luck!
Jason Aschle
Good luck!
Jason Aschle
Thanks for all the responses. A T-56 swap isn't out of the question, although I am leaning towards keeping the car basically stock/original. A guy I know in the Kansas f-body club has a black 1991 Z28 with a T-56, I'm not sure if is a 350 or 305, but is is a TPI engine.
Would you guys consider an IROC-Z (1987-1989) or a 91-92 Z28 more collectable? Like I said, this car will mostly be to look good, not go that fast. I'd have to sink a lot of money into the TPI engine to get it as fast as my 99 SS was stock. I'm not sure if these cars will ever be collectable, but I think they will in 5-10 years, especially the sought after models/option packages.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
A '90 IROC is pretty rare, since the 1990 MY was a very short one, especially if you can find a G92 car...
My personal preference would be an 85-90 IROC....they look much cleaner (smoother) than the 91-92 Z28s.
Car: 93 240SX
Engine: LQ9
1LE is rare yup
90- 62
91- 478
92- 705
But like i said, seems nobody around here even realizes how few G92 5 liter 92s were made, take a look at production numbers for 90-92 cars and the rules they were built by, a 350 car was supposed to automatically have G92, a little research and you'll find out how little were made
I've quite possibly got the only black / red striped G92 5 liter heritage
90- 62
91- 478
92- 705
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Originally posted by f355bird
I would also agree the iroc is by far the best looker for camaro's. If i bought another thirdgen it would be an iroc without a doubt.
I do not want to start a pissing match or anything between Iroc’s and 91-92 Z’s. But I believe the Iroc’s are the most sought after thirdgens.
Engine: 5.7
Originally posted by IROCThe5.7L
:werd:
:werd:
Which is cool....I just hate it when people tell me "to bad it's not an IROC"
Engine: 5.7
And a friend of mine has one...and recently totalled it
Car: 89 Iroc-z
Transmission: TH400
i wish mine was a G92. its an 89 with the 9 bolt and 2.77 gears. the G92 had dual cats and 3.27's i believe for the 5.7 liter cars.
i thought all G92's were 1LE's????
Car: 1988 IROC-Z
Engine: 427 SBC
Originally posted by 84customZ28
Without a doubt, your right, but alot of people just want the "IROC" name. You could take a..lets say a 1987 Z28, put an IROC-Z Decal on the door and people with not much knowledge about 3rd gens will think it's an IROC....not knowing about the different options the IROC has over the base Z28. To the public that don't know much about the 82-92 Camaros...they will just about call every base Camaro, RS, IROC, Z28...whatever an IROC because of what type of car it is
I hear ya.
I like the 91-92's alot myself
My buddy has a 92 B4C
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
Get a 1990 Iroc Z with the 350 TPI. Not only was this the last year of the Iroc, but the 350's were also still available with T-Tops.
Then put on the 91-92 ground effects and 5in. spoiler and call it a day...
Then put on the 91-92 ground effects and 5in. spoiler and call it a day... Supreme Member
Engine: 5.7
Car: 1999 30th Anniversary Pontiac T/A
157,000 IROCS vs. 17,000 91-92 Z28s... go figure get a 25th ann one, that should be a collectible later, but its true that an IROC might be more valued than an 91 z28 later on... the fact remains however that there are not many 91-92 z28s at all in existence today... if they only made 17,000 of em.... a good chunk must be totalled or totally wrecked.. in a decade or two, we all might end up owning a piece of history much in the same way those 69 camaros are... plus, if they reintroduce the camaro into production, it can only make our cars more and more popular.
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
How is old Fort Riley? I was stationed there 1983-85.
Fort Riley was established in 1853. I've been here since July 2002, but I've only actually been physically here about 1/2 the time due field exercises and a deployment. It's actually alot nicer than I expected. It is a pretty area. After living in CA most of my life, I'm not wild about the Kansas climate and bugs.
As for the cars, I guess time will tell. It will probably be another 10-15 years before the cars are collectable, like the 1st and 2nd gens.
Engine: LS1/L98
Transmission: A4/A4
Actually they are starting to appreciate now. The third gen is the new collector car. So now is the time to decide if you really want one while you can still get OEM parts from GM.
What part of CA are you from? Yea, That Kansas climate sure does suck! -20 in the winter to +115 in the summer. Sure glad I'm not there anymore.
my bad..
