iroc wheels
Old Jan 15, 2005 | 03:51 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
iroc wheels
which size tire should i use for a 8.5 wide chrome iroc wheels? i want to put some 275 wide tire. do you think it will fit?
Old Jan 15, 2005 | 03:57 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
i was lookin for a 275 for my 16x8 irocs but they dont exist. well they do but not the ones i wanted. provided your irocs are 16 inch the best tire ive found is a 255/50 rear and a 245/50 front. plus correct me if im wrong but arent irocs 8 inchers not 8.5. anyway the only 275 i found was a 275/60/16 to much of a side wall for my tastes. if your rims are bigger than 16 tho you should be able to find a 275. and it will fit and look great. good luck
matt
Old Jan 16, 2005 | 01:54 PM
camaro86's Avatar
Car: 91 z28
Engine: 350 tpi
their some irocs that are 8.5 depends where you buy them
Old Jan 16, 2005 | 02:44 PM
klumb15's Avatar
this is a little off subject, but i'm curious, on my stock irocs, REAR and FRONT is stamped into the metal on one of the spokes...but the wheels have exactly the same tires on them...can i do a 4 wheel rotation, or do the FRONT rims have to stay on the front, and the REARs have to stay on the back??
Old Jan 16, 2005 | 03:51 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
My 92 Z28 rims say that too. I think all third gen wheels do... I just leave 'em where they belong. They may be weighted differently or somthin, don't wanna mess em up.
Old Jan 16, 2005 | 03:54 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I Think the back and fronts have different offsets.
Old Jan 16, 2005 | 04:40 PM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
you can't rotate them, they are different. Rear is for rear only and vice versa.
Old Jan 16, 2005 | 04:43 PM
klumb15's Avatar
but why?
Old Jan 16, 2005 | 04:44 PM
all iroc rims and all 91/92 z28 rims are offset differently front to back. these wheels can not be rotated due to this. front on fron, rears on rear.
Old Jan 16, 2005 | 08:11 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The backset is different on those wheels. Fronts on back will stick out pretty far, backs on front might work but not quite right. I think this design just sort of grew over the third gen years and they didn't want to redesign the car to fix it as they did on the fourth gen cars. Note our cars use the same lower A-frame and brakes as an S10 pickup for instance.
BlueIroc-Z
Jun 9, 2019 03:22 AM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
