RAM AIR BOX pics inside
Your cold air feed looks good. You should consider making a box/cube our of aluminum or fiberglass to seal it off from engine heat and make it fully functional.
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Jeremy,
That looks pretty kewl.....do you notice any power gains though? Do you have to adjust your fuel regulator to accomdate for the influx of air?
Did you make the kit yourself or can you buy it from somewhere?
well no actually i went to home depo and bought the biggest electrical box i could get, used a dremel tool to shave some things off took some tin made a funnel bolted it to box, painted it black and cut off any bolts that were sticking out, im sure i could have made a better one , but im putting trans effects on soon so i probally will redo it, and make the scoop alittle bigger,as you can see from the pic i have one bolt shown that looks kinda dumb just i havent had time to cut it off, so anyhow i took some 8 inch duct and ran it up to my old air box,removed of coarse) then took a speed denstiy k and n and hooked it up, if i had the time and garage and tools im sure i could do a better job, but as far as diffrence absoulty throttle reponse is the biggest thing that ya notice, when i get my ram air 2 hood i probally do away with the whole setup and just get air through the hood,
hey jeremy love the idea what did u make the scoop out of? what size k&n filter is that do u have a model number? what modifacations did u have to do to the stock hose? anything else u could do to explain this would be great.. thanks
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
I could be wrong, but I that looks like a filter for a 3000GT.
K&N makes a 6x3.5(?) diameter filter with a flexible mouth that a few people have used with PVC piping to make cold air feeds for their Firebirds, flyin89fta(?) did this.
hey jeremy what did u make the scoop out of??what else did u have to do to the stock air hose? if u could email me with info thanks
do you work at best buy? I thought I saw this car in the parking lot somwhere in North VA. or Fredericksburg. I took a pic cuz that is what I thought it was for. I wanted to do something similar.
i made the box out of a electrical box i got at home depo, and as far as the pipe i did take a blow tourch and cut alittle away from the inside so i could run the pipe up through between the fender i havent finished it yet probally when i get some time , but for now it works
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
