re-painting Ground FX
Old Mar 22, 2005 | 09:20 AM
bitchin85camaro's Avatar
Car: 85 camaro
Engine: 327
Transmission: 350, 6200 stall, w/ brake
Axle/Gears: soon to be strange 5.14
this is the 3rd time im going to do this because the paint has chipped or peeled. but anyways instead of painting them the red that they are again i was thinking about painting them a flat black, or a flat gray. im not sure how it would go with my car but im sick of kicking down money to only have the damn things peel after a year. my car is a dark maroon. i have some pictures ill dig them up. let me know what you guys think i should do. im really dissapointed about the paint peeling this time. i started to think about just saving all summer, winter, then next spring get it painted black.
Old Mar 22, 2005 | 09:42 AM
Car: 85 camaro
Engine: 327
the rear bumper
Attached Thumbnails re-painting Ground FX-c-documents-settings-paul
Car: 85 camaro
Engine: 327
drivers side side skirt
Old Mar 22, 2005 | 10:22 AM
Brazen's Avatar
Car: 91 Z28, t-top, 5.7l ZZ4 rebuild
Engine: 5.7L TPI
Transmission: 700r
Originally posted by bitchin85camaro
the rear bumper
A Nice Silver would look nice as well.... pretty popular as stock trim. It looks like someone is NOT prepping these things correctly. Go to any Auto Paint supply store and buy:
1: some inexpensive wax/degreaser solvent
2: a spray can or two of "flex Primer"
3: and if you're really ****, buy some "Plastic Prep" bonding agent, but not usually necessary.
4: Of course some 320/400 wet/dry sandpaper
CLEAN the parts FIRST with the wax remover. Then proceed to sand just enough to clean-up the peeling areas and roughened up the surface... unless the existing paint is really bad... then you might want to consider stripping it down completely. Another wipe with the wax remover with clean towels. Sprey the flex primer, wet sand with 400 if necessary. If you bought the plastic prep, do that right before painting. Now you're ready for a long lasting finish coat on those GFX.
Jim
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
