how to paint rims?
Old Mar 28, 2005 | 04:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
how to paint rims?
i really screwed up my rims, and the gold trim on them needs to be redone, i already used aircraft remover on them and got all the clearcoat off. i guess my next step is sanding them down. should i then primer it, then rattle can it, and top it off with a clearcoat?
Old Mar 28, 2005 | 04:57 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yes sand it down but don't just use spray paint , try using the hi timp engine paint and then some clear coat.
Old Mar 28, 2005 | 05:05 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
something like VHT will work? and use a normal clearcoat?
Old Mar 29, 2005 | 02:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I used spray paint on mine, and it's held up for over 2 years, though most of that has been sitting, lol.
Old Mar 29, 2005 | 10:29 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i redid mine. all i did on part of them was, strip, scuff, tape, prime, base coat, clear coat. but i went the PPG route.
Old Mar 29, 2005 | 11:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
PPG route?
i cant find a gold paint
Old Mar 30, 2005 | 06:58 AM
drdave88's Avatar
Engine: 6.0L
PPG is a company. they can mix any color known (or unknown maybe) i work at a body shop though, so i have easy access to it. you might want to try calling around paint stores and see once what they can do for you.
Old Mar 30, 2005 | 11:35 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I used Professional Grade Rust-O-Leum gloss black on mine, did 8 or 10 very light coats from various angles to get complete coverage. It's held up great so far and it's been over a year on a daily driver...
Attached Thumbnails how to paint rims?-c-documents-settings-c1328
Old Mar 30, 2005 | 12:18 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
duplicolor makes a wheel paint that works pretty good. i used it on my brother's trans am, it's held up so far. i have no idea if they have gold, i've seen black, silver, grey, and clear.
Old Mar 30, 2005 | 02:33 PM
Bombero's Avatar
Car: 1986 IROC T-Topz Black/Black w/Gold Decals/Rims & Badges
Engine: 305 TPI stock
Travis,
take a look at this pic of my TPI, its the same paint im going to paint my gold rims with....I used Duplicolor Heat paint, even the clear is Heat paint...Ive used it before and it holds up great...just lightly sand, tape off what you want then paint it, use several coats of gold till you get the shade you want then use several coats of clear.....show some pics when your done, when mine are finished ill post some too.....
Attached Thumbnails how to paint rims?-c-documents-settings-prfd
Old Mar 30, 2005 | 03:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
whats the part number to that? the official paint code gm used is 92P. is thier maybe a cross reference a paint store could tell me? i worked on my rims just now today, pretty much stripped of all color as of now.
Old Mar 30, 2005 | 08:10 PM
Bombero's Avatar
The gold is: DE 1604 Universal Gold
The clear is: DE 1636 Clear
Its the engine high heat enamel with ceramic 500 to 1200 degrees
you can get it at : Advance Auto, AutoZone,NAPA or even WalMart.
The gold is so close you cant tell the difference....
Old Mar 31, 2005 | 12:22 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok im gonna take your word on it, that it matches real well, i work at an autoparts store, so i gotta order me up some, that color is non stocking from what i checked. how many cans to do 4 rims ya think?
Old Mar 31, 2005 | 06:50 AM
Bombero's Avatar
from what I've used so far I would say 3 of the Gold and 2 of the Clear, they are 5 bucks a can. Just make sure you paint them on a warm day, I painted my parts outside in the sun and the paint laid down and blended real nice, it also stayed tacky enough so when it came time to clear it, sprayed nice and even (no "zebra" stripes or overspray lines)
Old Mar 31, 2005 | 12:21 PM
transram88's Avatar
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
i know this forum is about wheels, but here's a pic of my tpi i painted
Hotrodboba400
Dec 10, 2019 07:07 PM
birdman_29
Jan 7, 2017 08:24 AM
Lanz06
Sep 14, 2015 07:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
