Urethane?
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Urethane?
So, I have my painting supplies picked out, all HOK. I chose the jet set black urethane solid over black Ko-seal II primer/sealer, over Kwikure 2 part epoxy chromate-free base primer. They state that a clear isn't necessary. Anyone use the urethanes without clear? If so, how's it look/holding up?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Urathane is a single stage paint. No clear needed. However, a lot of people will clear it anyway, that way you can wet sand the clear to give it a real slick finish.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can wetsand and buff a single stage urethane paint no differently than doing it with a clearcoated finish.
Car: 84 Z28HO
That's what I wanted to hear. The UB04 is a single stage urethane. Save some bucks. Would a gallon do 3 or 4 coats on a t-top car (should be enuf for wet sanding?), or could I get away with 2 or 3 quarts? The sealer is also black, which should stretch out the first coat a bit, I hope.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
