4thgen SS wheels on 3rdgen, what adaptors are needed? what the bolt patterns/offsets?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Does anyone have the info on what adapters are needed to run the 17"x9" SS wheels on a thirdgen? Also, does anyone know the bolt patterns or offstes of both wheels? They are the 91-92 Z28 style wheels, 16"x8". This is actually for a friend of mine with a 98 S10 that he is switching from the Z wheels to (hopefully) the S wheels. Thanks.
-Brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-Brian
Brian's 1991 RS
Car: 1984 Camaro Z28
Engine: Blueprint 383
4th to 3rd gen requires 2.5" spacers. The 16x8 Z28 wheels have a 0 offset in front and a 16mm offset in the rear.
Later,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 @ 94.77mph
Later,
Craig
the spacers you need for those wheels are 2.25" spacers for the front and 1.25" for the rear , I have the Ws6 wheels on mine , and those are the spacers im using , i got them from skulte
http://www.skulte.com/adapters.html
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
