Tree sap removal...
Old May 25, 2005 | 10:49 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Tree sap removal...
Yes, I actually did do a search on this, which is why I'm posting this.. I found alot of responses on getting sap off, but alot were pretty either contradictory or totally different... So, between clay bars, WD40, bug/tar removal, what's the besT?
Old May 25, 2005 | 11:39 PM
Kandied91z's Avatar
there is no "best" as it depends on too many factors. bug/tar isn't bad but it's potent stuff that can eat away the best clear if not used correctly. i'd try using a clay bar first, if that didn't work i'd try the bug/tar or diluted goo-gone. the clay bar should take care of it though.
Old May 26, 2005 | 05:52 AM
Lazer's Avatar
Car: 1989 Iroc-Z / 1985 Camaro
Engine: 5.7L 350 / 2.8L V6
Although I'm not sure how good it is for the paint, it deffinately works good on glass: rubbing alchohol. It just dissolves sap right away.
Old May 29, 2005 | 01:29 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I use castrol super clean. It doesn't really matter what you use as long as it works and doesnt' eat the paint. You will have to wax any spot you are removing sap from. No matter what your using it's removing your wax with the sap.
Old May 29, 2005 | 01:12 PM
82knightrider's Avatar
Transmission: TH200C....700R4
A soft cloth wth a bucket of hot water and soap.
Old May 29, 2005 | 01:46 PM
Car: 1982 Z28
Engine: 350 HO
All right.. It's reall warm out todau, 85 or so, so I'll try the water first.. I've got some superclean.. If that doesnt work, I'll pick up a clar bar to use.. What kind of lubricant is needed? I read you need detailing spray, or something like that?
Old May 31, 2005 | 01:43 PM
Kandied91z's Avatar
usually comes with the bar. mothers is around $20 with the spray and bar.
Old May 31, 2005 | 10:55 PM
pandctransam's Avatar
Car: 85 T/A
this has always worked well for me .. cold water no soap just water....an old trick from my late brother.
BlueIroc-Z
Jun 9, 2019 03:22 AM
gruveb
Sep 29, 2001 03:06 PM
JOHN/88IROCZ
Sep 29, 2001 08:51 AM
prepz28
Jun 8, 2001 02:25 PM
