camaro hood on firebird
Old Jan 17, 2001 | 07:18 PM
kernel's Avatar
i know the obvious differences on the two hoods being the flip up lights but other than that are they the same size and everything. i want to take this camaro hood and cut it for firebird lights to work and put it on my firebird. will this work. the hood is really light and it is not metaql or firberglass, it is like plastic like. dont know.
1987 pontaic firebird
2.8 liter v6,5 speed, hurst shifter,rapid fire plugs,borg warner wires,160 degree thermo,K&N,polished plenum,custom exhaust,modded air box,american racing wheels,3"tach,autogauge gauges,run with no spare tire,grant challenger steering wheel,firebird floor mats
pics at:http://www.gatherround.com/u114277a116822passs.invt
then click on guest view under pic #5.
Old Jan 17, 2001 | 07:25 PM
gregz28's Avatar
I would deffinatly avoid that. Cuting and fabricating would not be feasable. If you want a new hood I would go to a local junk yard or order a fiberglass hood...
91 Z28 305 tpi
plans for 383
flowmaster cat-back
Ram air to K&N cone
Old Jan 17, 2001 | 07:55 PM
Andy89RS's Avatar
It's not only the headlights that you need to worry about. The overall curvature of the hood front to back is different, the firebird has slightly more curve to it. The only way to make it look right is to have a pro modify it, and then it woul probably be cheper for him to make one from scratch...
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Jan 18, 2001 | 01:07 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You'll also need to section it, 'cause the firebird hood is longer.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
I'llrocya
Feb 2, 2016 11:43 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
