Firebird headlights
Old Jul 21, 2005 | 05:56 PM
Abaddon_fallen1's Avatar
Car: city bus
Engine: turbo diesel
Transmission: auto
Axle/Gears: be damned if I know, it's not mine
Firebird headlights
Not the best work, but not bad considering I used Windows Paint. 1994-1996 GTP headlights, just to keep the Pontiac thing going.
Old Jul 21, 2005 | 06:39 PM
Firebat's Avatar
i think redraif did something similar.
www.redraif.com
Old Jul 21, 2005 | 09:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Firebird headlights
They won't fit exactly like that. They (the lamp housings) are larger than that opening so part of the lamp will be shrouded.
It won't be alot granted but, still.
Red used 2 pair of small driving lamps.
Old Jul 22, 2005 | 09:19 AM
RedLineByrd's Avatar
Car: 1986 Firebird
Engine: 305 LG4
Re: Re: Firebird headlights
Which way are they slightly larger? Vertically or horizontally?
Old Jul 22, 2005 | 09:40 AM
Firebat's Avatar
i'd guess both
Old Jul 22, 2005 | 02:07 PM
deadbird's Avatar
Engine: TPI 305/ v6
They will fit horizontally if the turn signal housing is chopped down as shown.
Vertically, they are simply too tall, close to ½", to fit like they belong there.
If you step them back, similar to a camaro, you could probably squeeze them in there but, the upper portion of the lamp would be shrouded.
Similar to what those half moon lamp covers people used to put on the single round lamps so they could drive w/the high beams on w/o blinding oncomming traffic.
Old Jul 23, 2005 | 09:40 AM
Car: 1986 Firebird
Engine: 305 LG4
Maybe they could be made to look good if you fabricated a new headlight door for them that was flat in the front instead of following the hood line. IDK how good or bad that'll look though.
Thanks for the info, Dead Bird.
Old Jul 25, 2005 | 06:25 PM
Car: city bus
Transmission: auto
Nah, I'm not worried about shrouding. I pland to chop down the nose indentions a little bit widen it out, make it look somewhat factory.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:53 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
