Ok, found the headlight conversion for you guys!
Old Dec 26, 2000 | 09:56 AM
FiReBReTHa's Avatar
ok, i was doin my usual ebay browse, i came across a kit, that allows you to put The new, single, halogen bulbs in.
im not to sure about it, itll change how your car will loook with the new color of headlights,
Tell me whatcha guys think, hey if theres enuff maybe a GP ?
Heres the link, and then a response i got from the guy, http://cgi.ebay.com/ebaymotors/aw-cg...172207&r=0&t=0
To: FiReBReTHa
Hi,
Yes, you can use other brands if you want to, but the auction already include a pair of Hiper Standard Watt Xenon Bulbs, if you want to upgrade to the High Watt instead of Standard Watt, you could. And it's way better this way compared to the factory sealed beam. Whenever the bulb burn out, you have to change the entire sealed beam, but for the sealed beam conversion kit, you only need to change the bulbs inside. Thank you.
Regards,
Kevin
Initial K Auto Concepts, Inc.
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Dec 26, 2000 | 10:53 AM
Mike 25th's Avatar
!!!BUYER BEWARE!!!
Be very carefull with those HID bulbs. If you buy a bulb that has even the slightest increase in watts, it will destroy the wiring in your car. I just bought some HID lights for my girl's VW (for Christmas) and they fried the entire wiring harness. Now I get to spend my week-end installing the new $529.34 harness. No joke! The dealership said that they have repaired over 30 cars this year for the same reason. I bought them form eBay as well, but from a different user...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
One Awesome Camaro Site!
Old Dec 26, 2000 | 10:06 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
This is interesting. I would like some more
info. Any other Third-Genners have any
experiences with these bulbs?
Tommy
Old Dec 27, 2000 | 12:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've used high wattage bulbs before and have had no problems. I'm not saying that it isn't possible though. I used bulbs in my firebird had had an 80 watt high beam and a 55 watt low beam for years with no problems.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 29, 2001 | 01:58 AM
JPrevost's Avatar
Car: 91 Red Sled
http://lightlens.com/headlights.htm
, Jon (91 RS too many mods to list), getting new engine in summer
Old Jan 29, 2001 | 02:36 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
First off, those are not HIDs. They are completely different.
Second, before you buy any bulbs, check this site out:
http://lighting.mbz.org/tech/info/bulb_types/
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 29, 2001 | 01:46 PM
MATEOZ28's Avatar
I bought some of those for my 91 Z and they work fine but I got a name ******* brand so mabye it was the quality of the product you got.
Old Jan 29, 2001 | 02:26 PM
'89Formula305TPI's Avatar
Are you guys referring to H4 (halogen) bulbs with that conversion?
If so, they are standard equipment for cars that are imported in here (Finland..)
You can get them with any color you want and different wattage 100W !!low beam!!
'89 Formula 305 TPI T-5
Check out my car HERE!
Old Jan 29, 2001 | 10:54 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
What size are our headlights 4X6 or 7X6?? I found several conversion kits.
Old Jan 30, 2001 | 03:38 AM
sheet outta luck's Avatar
LUKS has some of the best quality bulbs i've ever seen or owned. I have a full set on my 99 Xtreme, (2 low and 2 high beam) and ive had them on my truck since April of 1999. I have 80W low beam and 100W high beam. I paid $20 each bulb and it was well worth it. Those cheap a$$ pepboys and autozone aftermarket bulbs arent worth a crap for reliability. These arent really blue, like the ricers have, and they light up the road 2 times better than stock, without blinding oncoming traffic.
Old Feb 3, 2001 | 12:08 AM
XXROOXX's Avatar
Let me put in some info on this....since i have this "conversion" on my '87 Trans Am. 90% of all rice shops carry these conversion housings. That's all it is, a housing. It's exactly the same size as the stock sealed beam. As for wiring? non required! These use H4 bulbs which plug directly into the stock sealed beam plugs. It's reallly that simple. For those who are considering this....i do have a few warnings though..
1.) when they say non sealed beam, they mean it!! You should silicone the hell out of them otherwise they will leak.
2.) don't pay more than $50 for them
3.) Don't be a nut like me and put in 115 watt "gold ion" PIAA bulbs......i get high beamed by oncoming traffic all the time!! It's really annoying. I think i've perfected the art of high beaming them back just in time to flip them off while they stare blankly wondering how my lights just got brighter when they thought i had my high beams on.
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
