anyone know where to find the big black corrugated tubing used in wiring harnesses???
Old Dec 15, 2000 | 10:01 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i am in the process or rewiring my WHOLE car forward of the firewall, and i need some of that big "split loom" tubing or whatever it is called. i can find it everywhere in 1/2" and 3/4" sizes, but i need teh big stuff for the huge bundle of wires that runs along the firewall. anyone knwo where to find it? i need probly like 1" or maybe 1 1/4".
thanks a lot.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
Old Dec 15, 2000 | 10:04 AM
JoeG-89RS's Avatar
The stuff is pretty generic. I've seen it everywhere from Summit to Radio Hack.
Old Dec 15, 2000 | 10:19 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
no you cant find it at these places. like i said, i can find it up to 3/4" easily but the bigger stuff is really hard to find.
-brian
Brian's 1991 RS
Old Dec 15, 2000 | 12:38 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
check www.partsexpress.com.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 15, 2000 | 08:11 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Go to http://www.delcity.net/start2.html
select on-line catalog, then wire management then the picture of loom. All sizes up to 2" in their catalog, 1 1/2" online.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Dec 16, 2000 | 04:52 AM
sheet outta luck's Avatar
Low Glow sells it in 9 colors, and cheap too, http://www.lowglow.com
Old Dec 17, 2000 | 12:43 AM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Another place to try would be www.taylorvertex.com .......I'm pretty sure that's the website. It's the same company that makes the Taylor wires.
Old Dec 17, 2000 | 12:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I got a wire loom kit from here http://www.jcwhitney.com/catsubpic.jhtml?CATID=4119
should have every size you need
Da Boid
- 4 out of 5 people think the 5th is an idiot
Old Dec 29, 2000 | 10:42 AM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
Be sure to get the high temperature stuff! What you find at parts houses, Radio Shack, even Taylor is low temperature polypropylene or polyethylene. The high temp stuff is made of nylon and is not commonly available. I looked at the Del City site and recommend you get your stuff there. I bought mine at Anaheim Wire Products www.anaheimwire.com. You will have to call them for a quote and inventory. They won't sell less than 100' of any size and you have to watch them on their shipping charges, but their unit prices are a little better than Del City's. They sell the high temp loom (notice the gray stripe, just like from the factory) you need. You can get away with the parts store stuff away from the engine, but anything near the engine will have to be high temp or will melt - guaranteed!
'87 IROC 5.7l TPI - original owner!
Old Feb 3, 2001 | 03:40 PM
AustinT's Avatar
Does any body know where to get the High temp loom but not in big rolls. I am just redoing the engine bay and I need about all the sizes up to an inch. If I had to buy it in 100 ft rolls It would be well over $100
I just need about 10' of each size from 1 inch down
Old Feb 4, 2001 | 10:59 AM
camaro_dude's Avatar
I just goto my local "speed shop" (not parts store), and get it. It comes on a spool, and you can buy how much you need.
Old Feb 4, 2001 | 01:24 PM
AustinT's Avatar
Does your local speed shop have the High temp stuff? Its marked by a grey stripe down one side of it.
Old Feb 5, 2001 | 09:03 AM
Yes they do have the high temp stuff. Http://www.ramchargers.com
Old Feb 9, 2001 | 12:40 PM
AustinT's Avatar
Hey camaro Dude
I called a ramchargers in Taylor and The guy said they dont carry the hight temp stuff. Who do I need to call to get some High Temp stuff from?
Old Feb 9, 2001 | 02:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I bought the same kit from JCWhitney that deadbird did... it actually came with the big 1" stuff along the top of the firewall. But, it's definately not high-temp. I had a piece of harness that came near the exhaust manifold, and it melted onto the wires.
Oh- as long as the stuff's not near the engine, you don't need the high heat stuff... I think that's what you asked next. Stuff like headlight wires and fan motor wires and a/c wires and etc can use normal loom. If you've got stuff curving the engine, normal loom melts.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited February 09, 2001).]
Old Feb 9, 2001 | 08:54 PM
mcconahay37's Avatar
Been to a junkyard? You could probably get enough for your purpose for 50 cents to a couple of bucks. Might even just give it to you. I'm sure that newer cars use the same stuff, so you could probably pull it out of a relativeley new wrecked car.
82 Camaro, 350, Erson cam, ported heads, Crane Hi-6 ignition, Accel coil, Turbo 350 tranny with 2500 stall.
Old Feb 9, 2001 | 09:59 PM
I delt with the Madison Heights Mi store, when i picked it up. I hate to say this but it was for a ph@rd cluckstang.
<font face="Verdana, Arial" size="2">Originally posted by AustinT:
Hey camaro Dude
</font>
1992 Trans Am
May 10, 2023 07:19 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
