mesh grille inserts for z28 grille
Old Dec 5, 2005 | 11:35 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
hey, i just bought a z28 grille and installed it on my car. even though the grille looks a million times better than my rs one, the one thing i dont like is the fact that i can see my rad and all the crap behind it. i would like to install a mesh grille infront of it. how did you guys install yours? how did you mount it? how much do i need? thanks!
Kubus
Old Dec 5, 2005 | 12:38 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
i'm guessing that you dont have the fog lights do you? with the lights installed you can't see the radiator and all the junk back there...
Old Dec 5, 2005 | 01:58 PM
Car: 1991 Camaro RS
im not a big fan of the fog lights. sorry.
Old Dec 5, 2005 | 02:52 PM
BlueZee28's Avatar
i got ya. well then, i'm sure AutoZone has a few different styles of mesh. may want to check it out, i think it's pretty cheap too
Old Dec 5, 2005 | 05:05 PM
Car: 1991 Camaro RS
i dont have an autozone but ill look around. thanks. still no comments on how to mount it?
Old Dec 5, 2005 | 05:50 PM
Gr89RS's Avatar
Car: '02 Z06
For my old car I just got some mesh from home depot. I cut two squares out and bent the edges to "grab" each insert.
Old Dec 5, 2005 | 05:54 PM
BlueZee28's Avatar
it's easy, just get some sort of clips and just clip it to the back of the grill. shoot you can even drill a hold in the back of the grill with a screw driver and use zip ties to mount it...and you'll never see the holes
Old Dec 5, 2005 | 06:04 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
same here, you goto home depot and they have some 'gutter covers'...mesh that keeps leaves out of drainage gutters....its like 2 dollars for almost 3 feet, just cut and mount
....hahaha I dug this pic out, it gives you a good idea of what it looks like, I just find it funny how high my car sat last fall when it got out of the shop
Old Dec 5, 2005 | 07:27 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I bought the stuff from Discount Auto. It was a real bright aluminum, but reflects the black from the grill, so it blends in most of the time. I just cut it and used zip-ties to tie it to these bars supporting the front spoiler (not too sure what they were). It hasn't given me any trouble yet. Also, paint all the stuff behind the grill a flat black so it doesn't show through the grill like on CamaroGuy's.
*edit*
One more thing, make sure both the inserts are facing the same way. I know it sounds weird, but if they're not facing the same direction, then one side will look like diamonds, and the other will look like ovals.
Old Dec 5, 2005 | 09:03 PM
Car: 1991 Camaro RS
ill head over to home depot tomorrow then. thanks for all the info. Kubus
Old Dec 6, 2005 | 03:08 PM
Stevo's Avatar
Car: Pair of 92 Z28s
best shot of my mesh grille that i got right now.
home depo's gutter guard
Old Dec 6, 2005 | 04:53 PM
Car: 1991 Camaro RS
does anyone have any shots of how to mount it? should i do it myself or should i ask my bodyshop guy to do it? he wont charge me for it, i just dont really want to bother him with it... thanks
Old Dec 6, 2005 | 07:38 PM
Stevo's Avatar
i just kinda lodged it in there so its nice and tight...just cut 2 pieces to about the size you need taking the front grille off was nessicary for me but i dunno about how others did it.
Also make sure you shoot back flat or gloss black...cause like was said when the fog lights are removed it looks really ugly. Mine broke in a wreck so i decided to get rid of them and not put them back on.
CAMAROBEAV
European Region
Apr 29, 2021 04:54 PM
PurelyPMD
May 5, 2016 04:57 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
