just a teaser of the bay b4 paint...
Old Jan 16, 2006 | 10:03 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
so im a rookie at this work so go easy but im learning more than college can teach me
me and a friend have done all the work and for two kids im happy.
smooth fenders
smooth strut tower "lips"
smoothed frame rails
trimmed up the rad support
custom battery trays
and i have cover plates for the sides of the battery trays by the fenders
among a few other little things these are it. ive got a little more planned when the motors in though.
im not looking for perfection because to be honest i dont have the patience anymore to perfect every little thing, this has gone on long enough!!
Old Jan 16, 2006 | 10:04 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
damn my camera sucks
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
and im going to paint it too...well see how that goes
Old Jan 16, 2006 | 10:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Doesn't look half bad so far
The engine bay is quite the b____ to prep for paint. I know your pain
Old Jan 16, 2006 | 11:08 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks man all the welding was done with a cheap gasless 110 amp welder. hows yours coming?
you keep beer and cigarettes in a good friend and he'll do anything
does anyone have any suggestions for improvement?
Old Jan 18, 2006 | 11:51 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
looking good! This has become quite a trend, i see most show 3rd gens having it done in the future Try to stay patient and prep it well, you don't want to have put all those hours in so far and get lazy now! Be a perfectionist! lol
Old Jan 18, 2006 | 12:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
your right...i almost got lazy after sanding for a LONG time on the first attempt at the bondo but there are too many pinholes etc in the bondo and now im taking the time to do it right and put another coat on. i know i wouldnt have been happy with the result, ive wanted to do this for a year of so but just now finally got around to buying a daily driver, pulling the motor, and getitng off my lazy ***!
Old Jan 18, 2006 | 01:03 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
That's gonna be cool....can't wait to see it when finished.
Old Jan 18, 2006 | 09:45 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
thats a lot of bondo. are you using glaze or the heavy stuff? also, i hope you know those circles of metal are high spots that you should knock down with a body hammer.
Old Jan 18, 2006 | 10:33 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
actually that isnt much bondo at all. the circles of metal are not high spots either...higher than the metal under the bondo yes but not higher than the bondo.
the fenders were pretty smooth to begin with but because we did so much welding, grinding, welding, grinding, beating, cussing obviously bondo had to be laid to smooth everything out.
Old Jan 18, 2006 | 11:25 PM
deadbird's Avatar
Engine: TPI 305/ v6
Slow... due to difficulty of finding some odds-n-ends for the wiring I want to do. Other projects in the works (holidays put lul im my workload to get me stuff ahead a little) are surfacing again as well.
By your statement... apparently I'm that 'a good friend'. Though, I'm not complaining mind you
Your inners do seem a bit rough. I just skim coated my metalwork spots on mine and then a couple coats of high build.
I also didn't go for exterior body smooth like JeremyNYR did though. Which seems more like what you're going for.
This is all the more I did aside from the 2k primer...
Old Jan 19, 2006 | 12:43 PM
blk91gta's Avatar
Car: 05 silverado quad cab
Engine: 5.3
Transmission: auto
solomotorsports did that to his trans am and it came out nice!
Old Jan 19, 2006 | 04:15 PM
ZZ4 86 Z28's Avatar
dont be fooled by the way it looks or feels. when metal comes up, especailly like that (in patches) they are high spots, youll see it after you paint (especially if you go with black, and mybe not if you go with white).
Old Jan 19, 2006 | 05:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well i didnt bondo the entire fenderwell. i sanded on the metal exposed parts of the fenderwells more than the bondo to bring everything even and it defenitly feels smooth as the outside of my cars paint. but i do plan to put one more thin coat on to fix all the pinholes in the bondo.
any other suggestions before i cross the point of no return? what should i do to fix the high spots?
Old Jan 19, 2006 | 10:31 PM
ZZ4 86 Z28's Avatar
take a body hammer, point the pointed part at the high spot and beat it till its obviously low. cover the entire area with bondo (not just where the high spot was, the entire section). you can really sand the metal down that much, the fact that it is showing is an indication of a high spot. whenever you see whatever you are covering begin to pop up, you either stop, or if you still havent touched right next to it, you knock it down.
Old Jan 22, 2006 | 05:29 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks nicer than mine!
wish I had the time and the materials to so that w/ my car...maybe in 30 years...if its still in one piece by then.
keep it real,
Brandon
Old Jan 25, 2006 | 03:15 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well heres the completed project...turned out as good as i ever could have hoped. i could have spent more time on the bodywork but it just wasnt worth it; especially with all the rust this car has
i dont konw why it looks pink (cheap camera) but its bright white
Old Jan 25, 2006 | 04:48 PM
deadbird's Avatar
Engine: TPI 305/ v6
Looks like it turned out pretty good.
This is probably more the color it should be, huh ?:
Old Jan 25, 2006 | 04:53 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I think you had your finger over the flash thats why it turned pink, i've had expirence with this.
Old Jan 25, 2006 | 07:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks deadbird...i didnt use a flash but that itself could have been the problem.
it turned out okay, like i said good enough for me. there isnt too many others out there with smoothed fenders, battery trays and frame rails.
85projectZ28
Jul 30, 2011 09:00 PM
Primetime91
Jul 7, 2010 09:31 AM
fb305svs
Nov 7, 2006 08:52 PM
