Question about using polishing compounds
Alright guys, I've used the "compounds" method of polishing before with "some" success, but I was wondering if I'm doing something wrong.
I know WHAT to use, but not so much HOW to use it. For example, I found it very difficult to get the compound ON to the buffing wheel. It was a pretty hard consistency, and IMO, I don't think I was using enough of the actual compounds when I was going over the metal.
Does this make sense? Any opinions? Maybe I just got some stale compound!
J/K
J/K
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
I always get a damp/wet towel and spread the product onto the surface, then buff it off with the buffing wheel.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
lol the same thought hit me the other day because I was thinking about getting a buffer or at least a mother's polish ball this year......I guess it makes more sense to apply to the surface and work it in with the buffer than to put on the buffer and risk getting sprayed all over
Yeah, but the compound isn't liquid. It's like a hard clay. You can't wipe it onto the surface like a wax or a Mother's one step polish.
Engine: My legs
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I polished metal for a living one summer. Our compounds all came in large bricks. I would rub the brick onto the polishing wheel just briefly until the wheel changed color a little bit. You don't need a ton. I also cleaned the wheel often, otherwise too much crap would build up and you'd get little black spots on the metal.
If you're working by hand, or with some tinker toy buffing wheel, the wheel may not have enough RPM and torque to cut properly with conventional compounds. On the 3hp setup with 15" buffs, it worked very well.
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
