new headlights?
Old Mar 5, 2006 | 10:00 PM
crazyL's Avatar
Car: 85 T/A
new headlights?
i wana get rid of the stock headlights, what can I do to upgrade or what lights can I get? Just dont like my stock ones!
Old Mar 11, 2006 | 03:26 AM
Firebat's Avatar
You can replace the fogs with ones from walmart or any other parts store and then look for better bulbs maybe. As for cool looking headlights, I think either o'reillys or advance auto sell these. Look in the import/dress-up section. I think the headlights also are the same as s-10 headlights which explains the import section.
Old Mar 11, 2006 | 09:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Sylvania Xenarcs.I got mine on ebay..cheap.
Old Mar 11, 2006 | 10:01 PM
crazyL's Avatar
Car: 85 T/A
do you have any pics of them installed?
Old Mar 11, 2006 | 10:18 PM
black84z28-4spd's Avatar
mine were 40 from autozone and are brighter than hell
Old Mar 12, 2006 | 10:42 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: ?
Heres one.
Old Mar 12, 2006 | 04:56 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Sylvania Silverstar
Old Mar 12, 2006 | 05:16 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Originally posted by V8 Slayer
Sylvania Silverstar
Old Mar 12, 2006 | 06:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sylvania Silverstar
Yep.
JamesC
Old Mar 12, 2006 | 06:42 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so are the silverstars new housings all together, or just a new bulb?
Old Mar 12, 2006 | 07:14 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
if you have an H4 conversion then you just buy the silverstar H4 bulb.... if you still have the stock sealed unit... then you can buy the silverstar replacement sealed unit...
Old Mar 12, 2006 | 08:29 PM
crazyL's Avatar
Car: 85 T/A
where can i get these and how much?
Old Mar 12, 2006 | 11:46 PM
Trah84Z's Avatar
Engine: 305 V8
would all the stock wiring work with the silverstar replacement sealed unit? and does the fact that it is a ~sealed unit~ mean once the bulb burns out i have to replace the whole sealed unit?
Old Mar 12, 2006 | 11:51 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
You dont need to replace the wiring with the sealed replacements. Replace the whole thing when it burns out.
I have silverstars on mine, there sooo much better than the reg halogens.
Old Mar 12, 2006 | 11:57 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
the stock wiring will work since the silverstar runs at stock wattage.... it wouldnt be a bad idea to run a relay setup since your factory wiring is probably showing some age now... and you'll be getting some voltage drop across the wires...but if you get the "sealed unit" if the bulb inside burns out then yes you'll have to buy another "sealed unit" to replace that one...
but that was one of the first things i did when i got my firebird.. i switched out the stock halogens for the silverstars sealed units.... and i think once summer hits im going to switch to a H4 conversion then run some higher wattage bulbs with a relay setup... or if the funds allow it... a HID projector retrofit....
Old Mar 13, 2006 | 12:09 AM
Trah84Z's Avatar
Engine: 305 V8
$25 a pop seem like a good price? suppose i'll need 2 low beams and 2 high beams...so is $100 worth it?...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
