HELP! fog in brand new bumper lights!!!!
Old May 17, 2006 | 11:40 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I just bought those clear bumper lights off eBay and put them in. 2 days later one has fog in it... DAMMIT!! Thats why I trashed the old ones just after 2 years. It is hot and humid here in Texas and moisture is a problem. I sealed up the vent holes in the housings with black hot glue sticks before I installed them to help keep water out. I already have fog in 1 of them after just 2 days. I was gonna try putting rainX anti fog stuff in them, but it says do not use on plastic... DAMMIT!! Does anyone know a way to fix this problem??? PLEASE HELP ME........
Old May 17, 2006 | 11:46 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You don't say, get the FOG out of here! Whenever you allow heat into an encapsulated non breathing orifice you will have heat builup, hence fog. Don't block the opening allow more air maybe by drilling holes in the back.
Old May 18, 2006 | 12:03 AM
Xlr8torZ28's Avatar
Engine: LB9 & L98
the factory ones always build up fog because of that damn hole. I thought if I plug it, it would prevent the fog. I may try drilling small holes in the back, or just buy a new set, plug the hole again and then run LED bulbs... I wanted to know if there was something I could treat the inside with to prevent moisture
Old May 18, 2006 | 12:15 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am pretty sure some makes a spray to prevent fog for like bathroom mirrors, try that.
Old May 18, 2006 | 12:25 AM
Xlr8torZ28's Avatar
Engine: LB9 & L98
It all says do not use on plastic... someone said to try putting rubbing alchohol in the housing, shake it up and pour it out
Old May 18, 2006 | 12:28 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
use some dishwashing soap, mix in water, and pour into the housing, shake it and it should solve the problem. otherwise common "no fog" eye glass sprays would work as well i would assume, although the dishwashing soap has worked for me.
Old May 18, 2006 | 12:29 AM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Just put a saltine cracker in there.. works with the salt shaker
Old May 18, 2006 | 12:55 AM
Xlr8torZ28's Avatar
Engine: LB9 & L98
I actually thought about putting a couple pieces of rice in there... LOL
Old Jun 10, 2006 | 01:45 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Pics? Ebay auction link peraps?
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
Omega
Aug 10, 2015 12:46 PM
