Dog jumped on car !! What to use to remove fine scratches in clearcoat?
Car: oldsmobile
Engine: 3.88
Transmission: yes
Axle/Gears: yes it has axles
My dog's scared of lightning and jumped on my car in the garage scratching the front/side of the hood.
the scratches are in the clearcoat and aren't deep at all.
What should i use to remove this? Im fairly familiar with waxing/polishing but not with rubbing compunds and wet sanding etc. Any info/advice is appreciated.
the scratches are in the clearcoat and aren't deep at all. What should i use to remove this? Im fairly familiar with waxing/polishing but not with rubbing compunds and wet sanding etc. Any info/advice is appreciated.
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
Car: 1992 Camaro RS
Axle/Gears: Stock
You should probably try just buffing them first. If that doesn't work, then resort to wetsanding. We don't know how deep they are, so It's hard to say...
Car: 90 IROC-Z
Toothpaste! colgate total is the one I found to work the best. Just make sure it's a paste not a gel. Then after the toothpaste use either turtle wax scratch remover or Mothers. Hope this helps.
Mike
Mike
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Originally Posted by Cadillac
Swat the dog!
Bad puppy!
Bad puppy!
I DO THIS ALL THE TIME, p1500 grit wet sand paper till smooth, than 3M rubing compound with a whool cutting pad, than clean the area with windex and let dry(sometimes the scratches come back after buffing) than you buff with a swirl mark remover with a fine foam pad. Its really easy.
1992rs/ss
Jan 31, 2025 05:10 PM
db057
Aug 11, 2015 10:11 PM
