Chrome polishing Question
Old Jul 9, 2006 | 08:07 PM
Frantic370's Avatar
Car: '91 Pontiac Formula w T-Tops
Engine: 5.0 V8
Transmission: AT
I've been looking for a while now, and I've found thread after thread about polishing aluminum wheels, and I'm not sure if I should go about a different method for polishing my wheels. Mine are solid chrome, and if you look at the pic youll see what I mean. I tried a powerball, but that did nothing. Ill upload a better pic probably tommorow of the wheels up close. Any tips are appreciated!
Old Jul 9, 2006 | 08:23 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
I have used BRASSO it work great.....also NEVER DULL is good it's the same stuff,but it has a wodding in it BRASSO is a liquid........works great.
Good luck,
Mike
Nice looking car by the way!!
Old Jul 10, 2006 | 12:51 AM
JetSet96's Avatar
Car: 86 Z28, 2000 Firebird, 2004 SSS
Engine: LG4 carb, 3.8, 6.0 HO
Transmission: Auto, Auto, Auto
Axle/Gears: 3.42, 3.42, 4.10
Here's what I do for chrome wheel:
  • SOS pads ( I use them when I wash/they won't scratch & their cheap )
  • Never Dull (by eagle one) takes any water spots off left by wash & puts a great shine back on.
I use these products because they are very easy to use & cheap to buy.
Steve
Old Jul 10, 2006 | 02:44 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I usually use Mother's chrome polish on my engine and some other cars' bumpers with the powerball. It works pretty well for me.
Old Jul 11, 2006 | 12:44 PM
Frantic370's Avatar
Engine: 5.0 V8
Transmission: AT
This is what I mean. The powerball wouldnt get this out at all. Maybe the SOS pads will but if not what can? Maybe Ill have to buff em out?
Old Jul 11, 2006 | 01:47 PM
TeK-91z28's Avatar
Car: 91 z28 convert
Transmission: 5speed
Pits and corrosion, even if you run a scratching wheel or buff over it all it will do is open the pits and corrosion up more..
Old Jul 11, 2006 | 02:40 PM
Frantic370's Avatar
Engine: 5.0 V8
Transmission: AT
So do I sand it with a fine grit and then re-finish it or am I screwed?
Old Jul 14, 2006 | 06:14 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
I think you need to get then recromed. $$$ sorry. you could also get them powder coated.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
