HOw 2 FIX A CRACK ON A 86 IROC RIM
Old Sep 30, 2006 | 09:26 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
I have an 86 iroc rim and it has a hair line crack inside it. it leaks all my air out in less then a day.what could i use to fix this crack??? and is it repairable?? please help
Old Sep 30, 2006 | 09:29 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
gonna need a pic...
doesnt sound repairable though
Old Sep 30, 2006 | 09:44 PM
Car: 86' Z28 Camaro
u cant really see or feel it leak it just comes out it about where the valve steam on the opposite side on the inner side
Old Sep 30, 2006 | 10:22 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Cracks in aluminum wheels can be extremely dangerous. Even tiny ones can grow. I'm more worried about safety than the air leak. Are you sure the wheel is structurally OK?
Old Oct 1, 2006 | 01:06 AM
rwdtech's Avatar
try bead sealer
Old Oct 1, 2006 | 08:30 AM
TireSmokin''s Avatar
I wouldn't try to fix it. Replace it. Vibration, and the other forces on it can make it explode or break apart. That is extremely dangerous, especially cruising at highway speeds. Be safe and replace it.
Old Oct 1, 2006 | 08:33 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I agree. It's cheaper/safer to get a new one. I bought one with a tire for $25!
Old Oct 3, 2006 | 01:45 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
My buddies dad owns a welding shop. He has welded on at least one of every set of 18"+ wheels around here. The roads around here aren't meant for those. Small cracks are fine. Grind the area down at the crack. Build back up by a reputeable aluminum welder. Grind the new weld back down. Sand and polish to make it look good. Take it to a tire shop and have it balanced. Not a big deal as long as it's a small crack, and it gets fixed correctly.
Old Oct 3, 2006 | 01:50 PM
MaineIrocer86's Avatar
Car: 1986 Z28
I would say get it fixed professional or dont do it at all...it will be cheaper to replace the rim then the potential alternatives..
Old Oct 6, 2006 | 09:22 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
ya i would try to find a place and polish those bad boys up
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
