H4 headlamps...
Old Dec 12, 2006 | 12:23 AM
C Murda's Avatar
Car: 91 Z
Engine: Somethin Nice!!
H4 headlamps...
ok tried searching and read all the possible threads but got nothing...i am currently looking into buying some good quality H4 headlamps and an HID kit but dont know the size to get. i see 4x6" 4x6.25"(rare) and 4x6.5"....which size should i get? which would fit with no mods?
Old Dec 12, 2006 | 08:06 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
so we answer so many questions that you guys have shut your brains off and just type before you think
call an autoparts store and ask what the size of the headlight that fits your car is
I dont mean to be an A hole but I would like to read about a challenging questions that may take a few of us to answer but I click and get this
if you need some info about the conversion you can pm me with good questions and i will be more than happy to help
first tip- without running a relay you cannot run the high voltage bulbs
Old Dec 12, 2006 | 08:21 AM
C Murda's Avatar
Car: 91 Z
sorry...i was just asking seeing as a good amount of ppl have done this swap. id like their input as to what lamps they bought and what size and if they had to do any mods to fit the lamps in. my local autoparts stores are filled with stupid ppl...
Old Dec 12, 2006 | 10:46 PM
C Murda's Avatar
Car: 91 Z
anyone?
Old Dec 12, 2006 | 11:29 PM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
Take a measuring tape out and see, here is the link for the H4 kit---> http://www.toucanindustries.com/inde...dlight%20Bulbs you will also need this from Summit Racing---> http://store.summitracing.com/partde...5&autoview=sku
Old Dec 14, 2006 | 01:03 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I think maros run the 4x6.... but you should find out the bulb number, then get the corresponding conversion.
Im getting ready to install a TRUE HID kit into my 87 TA.
"first tip- without running a relay you cannot run the high voltage bulbs"
IF he is in fact going to run true HID bulbs, the power consumption isnt that great. And the bulbs are usually lower wattage than stock halogen bulbs. I dont plan to upgrade my wiring at all. If I was putting in higher wattage bulbs, then yes. Heavy gauge wire and relays would be my plan.
That said...You gotta watch what you do with a true HID kit. To make it work properly, you should have projector lenses. They give the light a "cut-off" so that you dont blind on coming traffic. They make some projector style conversions in H4 housings in all sorts of sizes. Look on ebay. Even these projector conversion housings need some modification to work though. The projector lenses are just sort of floating in the housing. You need a way to enclose the bulb so that all of the light goes through the projector lens. I have a plan for that, and plan to do a full write up when I get into it. Im waitin for my bulbs now.
You can run them with standard housings, but you really need to aim them carefully, or else you will blind everyone else on the road.
That help ya any?? If you have any more questions post em up.
Justin
Old Dec 14, 2006 | 03:03 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I just bought some housings off eBay and the APC 4 light harness then re-pinned the connectors to match the wires. I also had to cut the backs out of the metal pieces that hold the headlight. If you use regular H4 bulbs it is HIGHLY suggested that you buy that harness or the bulbs will fry your stock wiring and headlight switch. I bought a true HID kit from ledgauges.com that I'll be putting on after Christmas. If you go that route then the stock wiring will be fine since those use half the power of the stockers.
Old Dec 14, 2006 | 06:36 PM
Car: 86 Trans AM
Bingo... ledgauges.com Thats where I got my set from. Nathan is an awesome guy to deal with. They are nice kits as well. I dont expect to have to cut anything off the back of my housings. Then again, camaro housings are smaller. So they probably arent as deep. The HID kit I ordered were the H4 6000k ones. Im hoping they more or less fit in the housings.
For the projector housings...Im going to try to take them apart, and make a cylinder to encase the light, so that it all goes through the lens. Then seal it back up. Those projector conversions from ebay are cheap enough, if it doesnt work....trash can.
Justin
K-slice
Mar 10, 2011 10:42 PM
