how do I clean the entire engine bay
Old Dec 14, 2006 | 09:33 AM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
When i bought the car it had a long term oil leak that was caused by some *** pirate not tightening everything down right when they finished working. Anyway this retarded lady i bought the car from never thought leaking oil was a problem and just kept addiong more so theres no damage just a big mess. Everything is covered in oil except for the parts ive replaced. I was wondering what the best way to get all of this oil off is. My friend has a power washer but i dont know what i can and cant power wash really because i cant see what i cant maess up with a power washer. I heard grease lightning works really well but i dont really feel like climbing into the enigne bay to get all of those hard to reach areas. If i have to i will but its not on my lst of things to do before i die.
Old Dec 14, 2006 | 11:04 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Thats what I would do, get a gallon of grease lighting and soak it down. It helps to get the motor a little warm before you start spraying. Then let it sit for a little bit but keep soaking it.....then take the powerwasher to it! Your not going to get 100% of it unless you pull the motor out. So just do the best you can. Just make sure where your car is parked.....you dont mind it getting all dirty.
Old Dec 14, 2006 | 11:38 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yep..my car had a oil leak for over a year before i decided to fix it. the underneath of the car was covered in oil. nasty stuff.
i just put the car up on stands, and went under there and soaked it in engine bright degreaser. took several cans to it. Then i powerwashed the crap out of it. haha. it worked very well, but some didnt come off. so i repeated the steps and in some places i took a scrub brush to it. the car came out pretty clean, and i still have some spots i'd like to redo. but it came out clean
i would just be alittle nervoous spraying down an entire engine tho.... powerwashers have very high pressure sprays and i just dont like the idea of the electrical stuff being around that.
Old Dec 14, 2006 | 12:27 PM
Car: Fire Red 89 RS
Engine: 2.8L :(
thanks. how many electrical things do i have to watch out for like the altenator and dis cap because i guess i could just not go anywhere one weekend and bum some rides to places if i wanna go and i could take all the **** out of the car and then just go nuts.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
