Where can I get wire mesh inserts for my hood opening?
Old Dec 18, 2006 | 05:40 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am getting a daytona style hood for my 86 Z28, and on the sides there 4 little opening and I would like to put some kind of metal or plastic mesh/screen.Kind of like what the ss hoods have in the front.
http://www.americansportscardesigns....ages/s-286.jpg
Old Dec 18, 2006 | 06:06 PM
redlsone's Avatar
you could try home depot, I put an iroc bumper on my rs and didnt put fog lights in the holes. My father in law had some mesh and in worked mout fine.
Old Dec 18, 2006 | 07:17 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
try looking for "gutter guard" it's plastic....it looks great
Old Dec 19, 2006 | 12:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya gutter gaurd will work pretty good as long as you secure it good to the back side. Any of those large chain hardware stores should have it or something similair to it. I would use a 2 part expoxy to secure it. Just make sure it will work on fiberglass and the material you are buying.
Old Dec 20, 2006 | 01:56 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I have an Iroc daytona hood and thats what I just bought for it. Haven't installed it yet, but it looks like it will work pretty good
Old Dec 20, 2006 | 08:28 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i got some from eastwood co. they have metal mesh in diffrent colors nice stuff.
Old Dec 20, 2006 | 09:12 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
If you want to keep a "stock" look, 87-92 GTAs and Trans Ams had this square mesh underneath the hood grills. (Probably 85 and 86 T/As as well) I don't think its super flexible or bendable, but you could cut it to fit. The bars are wide enough so you can have them painted (which is what I'm doing) or chromed if you wanted them to stand out.
Again, its a basic square pattern, nothing terribly exciting.
-Bill
Old Dec 21, 2006 | 06:42 AM
BLACK Z's Avatar
Car: 86 Z28
keep the ideas coming thanks
Old Dec 21, 2006 | 07:19 AM
BOTTLEDZ28's Avatar
Transmission: A4
if you cant find any material at home depot or something then try ebay. They have sheets of grill mesh in black and chrome for under $10
Old Dec 22, 2006 | 09:50 AM
BLACK Z's Avatar
Car: 86 Z28
Can the metal gutter guard from home depot be painted? does it rust?
Old Dec 22, 2006 | 09:54 AM
BOTTLEDZ28's Avatar
Transmission: A4
more then likely that meatal gutter gaurd is either made out of stainless steel or aluminum. That stuff is designed to be outside in all weather. and even it is is some cheap thin gauge steel, you can still apply some paint toit as long as you prep it correctly first. rough it up a bit, clean it, and then put some primer on it. then you can paint it any color you want. Just remember to use the proper primer if your going to paint over aluminum or stainless. I use 3M etching primer
Old Dec 30, 2006 | 08:45 PM
bfox88's Avatar
Car: 90 IROC-Z
pep boys sells metal auto mesh for the purpose of what you're doing. i think there's a black mustang on the package.
Old Dec 31, 2006 | 10:05 AM
BLACK Z's Avatar
Car: 86 Z28
There is not a pep boys anywhere near me. thanks though
Old Jan 1, 2007 | 05:23 PM
Iron_Maiden's Avatar
Car: 90 Iroc
Engine: L98 TPI
Axle/Gears: 3.23s
I have grill mesh on the front of my grill that has bowties instead of holes, might want to try looking for that. Ill try to get a picture it looks great and I love it
Old Jan 1, 2007 | 10:38 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Summit Racing has some differrent color wire mesh, free shipping and get it with in 3 days.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Jae992
Aug 27, 2015 09:07 AM
89mulletbird
Aug 12, 2015 07:08 PM
