85-87 IROC wheels on with some int. pics and a burnout vid
Old Jan 27, 2007 | 05:05 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
just recently aquired another set of 85-87 IROC wheels with gray inserts. not sure if i should leave them (they are in surpisingly good shape) or if i should paint them black. the fronts have a sumotumo tire on them and the backs are wrapped in nitto 555R drag radials. the light in these pics isn't as good as it could be unfortunately. by the time i got the car washed and to a place to take pics, it had clouded over
i also realized that i don't have many pics of the completed interior up. fourth gen seats and check out the clusters i've built.
and here's a link to a burnout with the 305...some folks were interested in it on another thread so here it is:
Old Jan 27, 2007 | 05:24 PM
'86 350's Avatar
Car: '86 Camaro SC
How do you like those Nitto's? Do they hook up pretty well on the street? I remember I pm'd you a month or 2 ago about them and you were talking about getting a set.
I like the interior too, the cluster looks awesome, although I'm surprised your not running the tach on the right side as opposed to the left, most people I've seen seem to run it the opposite of yours. Still looks cool though, what'd you use to make the cluster, just a slab of plastic or something?
Old Jan 27, 2007 | 05:35 PM
JimmyDavidson's Avatar
Car: 1984 Camaro z28/SC
Engine: 355
Axle/Gears: 9bolt 3.89
Looks excellent, very professional looking, any reason for swapping the taillights though? I kinda liked the way the grid lights looked on your car.
Old Jan 27, 2007 | 05:55 PM
Stevo's Avatar
Car: Pair of 92 Z28s
cool, looks good. Nice burnout.
The older tail lights give the car an "older" look so i guess it goes with what you were trying to create.
Old Jan 27, 2007 | 06:23 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
The Tach on the left gives you a better view than on the right, if I ever do mine again I`ll do it that way, looks good
Old Jan 27, 2007 | 06:29 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Also wanting to know why you put those taillights on. The others looked so sweet on there.
Old Jan 27, 2007 | 06:34 PM
'86 350's Avatar
Car: '86 Camaro SC
Interesting, I always thought it was vice versa. I guess you learn something new everyday.
Old Jan 27, 2007 | 07:13 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
No heat or ac?
Old Jan 27, 2007 | 07:29 PM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Heat and AC is for sissies!
Old Jan 27, 2007 | 09:01 PM
mw66nova's Avatar
Engine: 7.0L
the nitto's really don't do what i figured they would...i'm kinda dissappointed. i wouldn't suggest them to anyone putting big power down.
the reason for the tach on the left was really just for visability's sake.
the taillights? i wanted a change i guess. i've still got the grids and may stick those back in at a later date.
Old Jan 27, 2007 | 09:27 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
that cluster is sick man Love it, and the whole car
Old Jan 27, 2007 | 09:35 PM
'86 350's Avatar
Car: '86 Camaro SC
So maybe the BFG's would be better for hooking then? I'm assuming the Nitto's at least hook better then the 712's you were running before right? I know you just got the Nitto's, but have you tried heating them and then launching it?
I didn't even notice the tailights before, I just glanced at the pictures, but I don't really have an opinion on them, I think the older ones look basically just as good as the grids. The give it a different look. But not in a bad way.
Old Jan 27, 2007 | 09:41 PM
mw66nova's Avatar
Engine: 7.0L
they do hook better than the 712's, and i did notice after the burnout that they hooked better than they had, but they still aren't the best tire out there. the BFG's are better, but they don't handle as well (i'm assuming you're wanting to run these in autocross, since that's what you were into last time we chatted.)
Old Jan 27, 2007 | 09:46 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i have to agree with that, i really liked the grids on there but im glad you got some 85-87 irocs again they are the best looking wheels for your car imo but i like them alot better with the black inserts like you had b4, the polish on the old ones helped out a ton as well. i also like the look of the lower profile tires im not really a big fan of skinnies/fatties. btw does your console have any carpet on it, it looks pretty good like that?
Old Jan 27, 2007 | 09:58 PM
'86 350's Avatar
Car: '86 Camaro SC
No, these would be a street tire, I'm running a crapy pair of 711's right now on the street, and I can nail it in 2nd at about 35 and break loose, forget about going from a dig anywhere. They just don't hook at all. I've thought about a pair of Sumitomo's for the rear, a lot of people I've talked to seem to like them, but I figure the Nitto's might just be a better choice for the street as long as I could get about 15,000-18,000 miles out of them.
I do still run Auto-x (drag racing is really starting to interest me though) and I just run a set of stock camaro wheels or some steel wheels on just a decent set of street rubber for the cones. Eventually once I hone my auto-x skills a little more I'll hopefully step up to a better and lighter rim/tire combo.
Old Jan 27, 2007 | 10:06 PM
mw66nova's Avatar
Engine: 7.0L
nope, that's a base model center console with no carpet.
Old Jan 27, 2007 | 10:48 PM
Daytona T/A's Avatar
Car: 1983 25th Anniversary Daytona 500 Pace Car Trans Am
Engine: 5.0L 305 Crossfire-Injected V8
Transmission: 4 spd. auto
I love the rims! Don't paint them black!
Old Jan 28, 2007 | 06:13 PM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Every single time i see your car i drool, seriously, it dont matter wether you put steel S10 wheels on your car, it will still look awsome.
Old Jan 28, 2007 | 07:04 PM
mw66nova's Avatar
Engine: 7.0L
thanks for the compliments guys. about the wheels, i'm only talking about the inserts, the spokes themselves will be high polished if i do them. hopefully i'll be pooring more power to it soon
Old Jan 28, 2007 | 10:29 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i say make the inserts black. taillights are up in the air for me. interior looks amazing. i like the 85-87 irocs on your car. and lookin at the pics, the bottom kinda looked silver...that might actually look cool if you did that.
Old Jan 28, 2007 | 10:39 PM
Gramps's Avatar
Car: 87 Camaro IROC
i really like the way youve organized your dash cluster. very nice.
theres something about your rear turn signals, if you did to that what you did to your grids, i think it'd look just as good.
Old Jan 28, 2007 | 10:47 PM
mw66nova's Avatar
Engine: 7.0L
bottom of what? i'm not following you...
i didn't do anything to the turns on my grids...what exactly are you referring to? i polsihed/repainted both my grids and these stockers.
Old Jan 28, 2007 | 10:53 PM
ZZ4 86 Z28's Avatar
o my bad. where the gfx would be if they were on. that part looks like a light silver in the lighting. it might look cool painted like that. just a random suggestion. i know the paint is new though.
Old Jan 28, 2007 | 11:06 PM
mw66nova's Avatar
Engine: 7.0L
oh ok, i see what you're saying. no , i don't think that would look good...too many colors makes the car look busy.
Old Jan 29, 2007 | 12:20 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The reason is because of the keys. I did mine like mw's then noticed the tilt adjustment lever is in the way. I just set it where i wanted it and took the lever out.
Old Jan 29, 2007 | 05:34 PM
Demon355's Avatar
Very nice Matt. I like the 85-87 IROC rims better than all of them. Makes the car look meaner to me. I'd go with the grids but thats just me. About the cluster, I always thought it was easier to see the Tach on the right side rather than the left. I drive with my left hand on the wheel and my right on the shifter so seeing the right side of the cluster is easier for me. Nice car though dude, I love it.
Old Jan 29, 2007 | 06:46 PM
Gramps's Avatar
Car: 87 Camaro IROC
MATT, i was referring to your sig, in your sig you have the grid style lights, and i think the turn signal is painted red to match the rest of the grid lights. but on the car your showing us in the pics, and i see you have the seperated style lights with the turn signals yellow. im just sayin that if you painted the turn signals red then it would look good.
PS: what are those tires on the car the ones described in your sig? the M/t's? or are they a diff dimension?
Old Jan 29, 2007 | 06:53 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
those wheels compliment that car PERFECTLY!! i also really like what you've done with the interior...great work man!!
Josh
Old Jan 29, 2007 | 07:46 PM
mw66nova's Avatar
Engine: 7.0L
those are not the tires described in my sig, they are infact a nitto 555r drag radial in the 245/50/16 size. the ones in my sig are the kuhmo 712's on 88 IROCS or the 275/50/15 M/T's on rodlites.
the sig pic has been altered to get a cool effect, the grids have yellow turns in real life.
Old Jan 30, 2007 | 04:36 PM
ssean92's Avatar
Car: sold
i agree matt i like the older lights. and the wheels do look allot better. but i would say the black would look better. i have always loved your car!!!!!
Old Jan 31, 2007 | 04:37 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Cars lookin good man. i'm still psyched at the times you're pulling out of that thing. its faster than some of the "built" 383 cars around here!! good job man
Old Jan 31, 2007 | 05:22 PM
Stevo's Avatar
Ditto and i dont know anyone who doesnt drive that way...i mean ya sure when im crusing i may have 1 arm out the window and 1 on the wheel but when its business left arm on the wheel and right on the shifter...with the tach on the left side it would seem annoying to look the opposite direction.
Its all preference but to the rest of you is that the only reason or am i missing how it is easier to see on the left side of the cluster?
Old Jan 31, 2007 | 06:30 PM
yjischoking's Avatar
Car: 95 Acura Integra GS-R
Engine: B18C1
Transmission: 5 spd.
on my integra, the tach comes factory on the left. perhaps it has something to with it being rhd in japan? maybe its on the right for domestics.
Old Jan 31, 2007 | 07:11 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Car looks great man. I love the cluster.
I think gunmetal might look better on your rim inserts than black. Either way, it'll look great.
Old Jan 31, 2007 | 09:51 PM
mwright1129's Avatar
Car: 1988 Camaro IROC-Z
Engine: 5.7L 350 Small Block
Car looks awesome dude. I can't get over how clean your interior is! Mines horrid right now; needs total restoration.
Old Feb 1, 2007 | 06:55 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Nice burnout. Lots of power in that 305. Mind if you got a video of your idle/exhaust. Its in there faintly for a split second and I'd say thats a tease
Old Feb 1, 2007 | 08:25 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
When you watch the video look at the other videos in his photobucket. He has one of when it had the solid cam in it.
Old Feb 1, 2007 | 08:26 PM
mw66nova's Avatar
Engine: 7.0L
if you look in my album on photobucket, there is a vid clip of my car just idling.
thanks for all the compliments guys, i've worked pretty hard on it!
Old Feb 2, 2007 | 04:37 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
nice as always man.. and nice little tire squeal too
1984HO
Mar 19, 2021 11:59 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
mcquigg
Aug 13, 2015 02:26 PM
mustangman65_79
Aug 11, 2015 03:17 PM
novaderrik
Aug 10, 2015 12:44 PM
