t-tops
Old Feb 14, 2007 | 01:59 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
t-tops
everything on my car is almost mint except for my t-tops, is there anything i can do to make my t-tops look better.
Old Feb 14, 2007 | 03:34 PM
AmorgetRS's Avatar
What is wrong with the t-tops? Are the the lexan or glass ones?
Old Feb 14, 2007 | 03:47 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
they are lexan and they're scratched beyond belief. id like glass ones, but they dont fit.
Old Feb 14, 2007 | 04:06 PM
AmorgetRS's Avatar
If you have GM lexan t-tops then GM glass t-tops from 84-92 will fit. They recalled a lot of the lexan tops and replaced them with glass ones.
Old Feb 14, 2007 | 04:08 PM
Gr89RS's Avatar
Car: '02 Z06
So long as they arent scratched beyond belief or cracking, a good polishing job will take out all the oxidation and make them look much better..and who says glass tops won't fit your car?
Old Feb 14, 2007 | 06:16 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
my buddy had a 91 camaro and i tried to put his glass ones on and it didnt fit
Old Feb 14, 2007 | 06:18 PM
AmorgetRS's Avatar
My guess is the 91 Camaro had C&C t-tops. GM t-tops will fit.
Old Feb 14, 2007 | 07:11 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
any idea where i could get some glass ones that are in good condition?
Old Feb 14, 2007 | 07:21 PM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
If you cant find some glass ones or dont want to shell out the $$ for them you could always try improving the ones you have. you could wet sand them until the scratches are mostly gone or a lot less noticeable and polish them. A search will pull up a few good threads. heres one i had saved.
https://www.thirdgen.org/forums/auto...duct-do-i.html
Old Feb 14, 2007 | 07:29 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
T Top
There are several conditioning and sand paper kits on the market but you will be sanding a long time if the cracks are deep.
If you sand and then paint them with acrylic you'll not be able to view through them unless you have luck and find some smoke acrylic tinted clear paint.
I've been looking and have not found this type of paint yet, let me know
if you do.
Old Feb 14, 2007 | 09:53 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I took some 2000 grit sand paper and wet sanded all the oxidation off and hit them with my PC and some 3M plastic polish and they look 100x better than before. All the little tiny cracks are still there but they're in the middle of the lexan and you can't feel them from either side and the plastic is really smooth now. There's some scratching from the 2000 grit paper that I haven't fixed since I havn't found any higher grit paper yet but it'll work until I can get some glass tops.
Old Feb 15, 2007 | 02:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Above 2000, just use rubbing compound and glaze/polish... Not sure about using it on plastic, though...
Old Feb 15, 2007 | 07:45 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Hey while i was at the yard in stafford i swore i saw some good sets of glass and lexan t-tops at the yard. I do remember specific on a 91 bird some lexan ones that looked good. If you want the address i can give it to you or if you want to meet up there sometime i can give ya a hand. Let me know here or PM.
-Steve
Old Feb 15, 2007 | 10:45 PM
91badgreen's Avatar
Car: 91 firebird
Engine: 3.1 v6
yeah thanks for all the suggestions, but i took off my t-top earlier today to check something out and i didnt snap it back on all the way. On the way out of my neighborhood it jostled loose and when i hit about 35mph it flew off, hit a guard rail, and cracked. so always make sure your t-tops are secured and locked. yeah steve ill send you a pm about those t-tops you were talking about
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
