Once and for all - are GTA wheels powdercoated or painted in the center?
Old Feb 22, 2007 | 10:14 AM
titan20's Avatar
After much internal debate, I've decided to stick with my gold GTA wheels (getting 255/50 and 245/50 Falkens installed today). However, like most others, my clearcoat sucks on the outside rims of the wheel. The gold in the center is in perfect shape. My question is - are the wheels painted or powdercoated? I've done searches and came up with different opinions on this. The reason I want to know, is because I want to remove my clearcoat and polish the outside rims. If the center of the wheel is indeed powdercoated, I think I could use weak spray on paint stripper to get the clearcoat off (concentrating on spraying the stripper on the outside rim), without harming the gold centers. If not, I guess I'll have to go with the sanding route. I was just thinking that if I was careful, I could strip the outside part without harming the centers.
Old Feb 22, 2007 | 10:18 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Im pretty sure its paint... Someone posted the color match to it somewhere so you can match the paint after you strip them down. I guess it could be the color match to the powdercoat...
But here is a stupid question. Did they have powdercoat back then? If they did, which they probably did, would it have been used in applications like that back then? I thought powder coating was fairly recent stuff.
Plus I would think powdercoat would make a smoother surface after it dries. There is plenty of roughness to the center section of the GTA wheels. Its not glassy.
So I say its paint...
Justin
Old Feb 22, 2007 | 10:26 AM
Stephen's Avatar
Car: 87 GTA
Yeah, paint.
Check out www.gtasourcepage.com for any othe TA info you need.
Old Feb 22, 2007 | 10:34 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
THEY'RE PAINTED!
Old Feb 22, 2007 | 10:44 AM
titan20's Avatar
Thank you very much. I guess that pretty much only gives me one choice on stripping the clearcoat (unless I want to paint the centers again). I don't know where all those people got the powdercoating idea either.
colton_carlson
Mar 8, 2019 12:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
