How do you Remove corrosion??
Old Mar 25, 2007 | 08:24 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
How do you Remove corrosion?? I removed the clear coat today off my 86 Iroc's with aircraft paint remover and the corrosion is still there..i was wondering if someone knew how to remove it easily?
Old Mar 26, 2007 | 10:16 AM
xgtharo86x's Avatar
Car: 86' Trans am
Re: How do you Remove corrosion??
ttt
Old Mar 26, 2007 | 12:39 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Im not a body guy pro by any means, but I guess you just either sand it down with a rough grit sanding paper or, blast it away with a sandblast gun w/ a soft media. Im sure others will chime in to tell you whats best. I guess a picture could be useful too.
Old Mar 26, 2007 | 12:50 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Abrasives are the only way to remove corosion. Chemicals will only work so much. Then when you do so seal it to prevent the electrolyte from corroding the cathode and anode.
Old Mar 26, 2007 | 09:22 PM
xgtharo86x's Avatar
Car: 86' Trans am
i sanded them down with 400 and 600 grit wet sandpaper after using aircraft coating remover this is how it came out
Attached Thumbnails How do you Remove corrosion??-l_bbf50384867d635e2d5fef713f7fdd92.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
sahlomonic
Sep 20, 2015 07:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
