Need Pics Of 18"19" and 20" wheels on Camaro
Car: 1991 Camaro RS convertible
Engine: 305 Tb
Transmission: 5 spd soon to be T56 6 speed
Axle/Gears: 3.08 soon to be 4.56
Im looking at addings some 20 inch wheels on my 84 camaro and would like to see which size looks better on the car, right now i have 17x9.5s and am really boared with them..
Post your pics (please dont post pics of just wheels)
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Re: Need Pics Of 18"19" and 20" wheels on Camaro
those 20's look good. what size rubber, 30 series?
Engine: 305 Tb
CAMAROGUY
THat car looks awsome..
Here is a pic of a camaro with 19s that looks awsome too..
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
Car: 1988 IROC
Transmission: TH-700r4
i highly doubt those multispoke wheels on that blue car are body hot rods. the 18's jtmiller posted are boyd Junkyard Dog wheels
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
18s
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
yea the hotrods are the ones I have...the 19's I think they are asking about could be one of many billet wheels that are made (boyd has a few sets that are similar to them)
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
jtmiller92,
Fab looking car. Don't see too many green Camaros. Very nice indeed and different.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 90 Camaro RS
Could you guys with 19's or 20's please let us know what offsets you used?? I am looking at a set of 20 inch Zinik Z12 Mazottis in black for my 1990 RS but my wheel mechanic reckons they wont fit as the rim may rub on the front strut. I don't really want to go as low as 18 if possible.
My car has been lowered 1 inch also, so hopefully that won't be a problem.
Any help would be greatly appreciated as he's getting a set of blank 18's specially drilled to fit my car this week and i'd rather go bigger if possible. (We can't get the correct stud pattern here in Australia so we drill blanks to fit)
Cheers
John
Cheers
John
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
These are Centerlines Ventura 18x9.5 all 4 corners with 6in back space. 275/35/18(front) 285/35/18(rear)
Car: 90 Camaro RS
Well i went for 18's in the end. Zinik Z12 Mazotti's in 18x8.5. A nightmare to get in Austraila but well worth it:
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
im not a fan of big wheels on muscle cars but 20 irocs look damn good on an iroc i would put 20s on an iroc just because they have that look to them that they can take it. i'lll let you know your wheels space is going to get very hard to fit nice tires under there
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
i am looking at a set of 18 inch rims for my camaro. the ones i am looking at are 18x9.5 fronts with the correct offset and backspacing to fit a fourth gen. i know that when we take a two inch adapter it corrects everything. will these fit on my 91 with said adapter given that they will fit a fourth gen? thanks
Car: 1987 IROC
Engine: 5.7
Hey fellas I have an white 87 Iroc. Im looking for the Replica Iroc wheels either chrome or the other machined. Im looking for info on 19 inch or 20 inch wheels and any rubbing problems that I may run into, Hopefully none! Id like to put on 275/20/35 all the way around IDK what will be optimal with a 19 or inch rim, any help would be great Thanx
Most of the replicas I've seen are 8" wide. That's a 245, maybe 255mm wide tire at most, especially on a larger diameter wheel that'd require less sidewall. That being said, with the right size tire, you shouldn't have any rubbing. Keep offset to about "0mm" , bolt pattern to 4.75" and overall wheel and tire height around 26" and you should be ok.
Car: 1987 IROC
Engine: 5.7
I'd go 245/30/20. ...that give you an overall height of 25.8" Stock was right about there. Just a hair under 26". ....and with such a small (30) sidewall, you're going to be limited on how wide you can go. I'd think 245 would be about it, but that's not a final answer, just my 2 cents.
Car: '89 Firebird
Engine: 7.0L
I think 18 and smaller you can say the car has wheels. 19 and larger it's more like the wheels have a car.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I very much agree. I like my 18" wheels, but for sure, I would not go any bigger in diameter
Car: 1987 IROC
Engine: 5.7
Im just nervous with 20's on the car up here in RI The roads suck compared to down south and out west. I also dont want to run into any rubbing problems with turn the wheels and or wrecking a rim from a pothole or bump of whatever ehhhh
