How to polish your tail lights?
Old Sep 22, 2000 | 06:22 PM
'89Formula305TPI's Avatar
My tail lights have lost all the gloss and started to fade, so I wonder what to do to make those look like this:
I'm very sorry if this hurted someones copyrights or so, I thought it was the best pic of shiny tail lights
'89 Formula 305 TPI T-5
Check out my car HERE!
[This message has been edited by '89Formula305TPI (edited September 22, 2000).]
Old Sep 22, 2000 | 07:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I was going to say take a quick trip to Home depot but then I saw where you live. All you need is an electric drill, a buffing wheel, and some polishing compound. But you want a fine grit. Check out the site where you got the picture, but if you dont have it here it is. http://members.aol.com/mmmm999/3rd-degree/tips/tips.htm
James
If the women don't find you handsome they should at least find you handy
Old Sep 22, 2000 | 09:16 PM
camaro 22's Avatar
try some plain old armoral. i use it on my camaro tailights and the shine very nice.
Old Sep 22, 2000 | 11:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Meguires Body Scrub rubbed vigerously by hand and then waxed will make them look that way as well
<A HREF="http://anzwers.org/free/gta" TARGET=_blank>87 Firebird
84 Camaro</A>
Old Sep 24, 2000 | 12:29 PM
Thanks fellos, but could someone define 'polishing compound'? Is there any known brand in the market? (read: something that might reached up here in Finland too..)
Old Sep 24, 2000 | 09:35 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I don't even think you need any power tools!!! The brand to look for (I guess) would be Turtle Wax...look for their "Polishing Compound." Polishing compound is a slightly abrasive liquid that will basically wear away the old, dirty surface of your lights (or anything for that matter) and give you a new shine.
I used Turtle Wax polishing compound when I put junkyard IROC tailights on my RS, and they came out like brand new lights!
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic/AT/T-tops/all power
Hypertech chip/2 K&N filters/Modded air box
Eclipse CD/Eclipse 100x4 amp/Boston4x6 plates, 6x9 RX 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Sep 24, 2000 | 10:11 PM
85CamaroXXX's Avatar
Crazy people...polishing coumpound this, cleaning that...just use plain, old toothpaste. Works like a charm. Rub on, rinse off. Repeat for added gloss. Works for teeth, works for lights. What more could you want in a product??? You may need something special to get that crazy gloss in the pic, but use the toothpaste first!
Old Sep 25, 2000 | 07:06 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Chrome polish will do a real good job of freshening up your tail lights, but will leave a slightly cloudy finish. After you get that far, you can use some plastic polish. (yes, it does exist. Maguires and a few others sell it, but the only brand I could find in my area was Blue Corral or Blue something). It made my tail-lights shiny enough to see a clear reflection of myself in.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 25, 2000 | 10:31 AM
Well, thanks a lot guys! again
I'll try different suggested methods, and let you know the results, thanks!
Old Sep 25, 2000 | 01:56 PM
hektyk's Avatar
zaino made my taillights shine like that and they were really dull.Go to www.zainobros.com and look at the pics.You can also order it online there too if you like.
[This message has been edited by hektyk (edited September 25, 2000).]
Old Sep 26, 2000 | 02:19 PM
89IROCZ
Guest
Posts: n/a
To tell you the truth.... if you clean your taillights when you wash your car and then put armor all on them, they look really good.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Sep 28, 2000 | 04:10 PM
Blade's Avatar
ANYTHING looks good with Armorall applied... but the fact is, dust stick to armorall like flies to **** and Armorall will wash away in a few days at the most.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 28, 2000 | 07:09 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
after reading this yesterday, i took some aluminum polish to my taillights...WOW!!!
looks great
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Sep 28, 2000 | 08:41 PM
[-sLaYeR-]'s Avatar
I used 303 Aerospace Protectant on my tail lights and interior, and wow, what a diff. The dash is a deep shiny black again, instead of looking faded. The tail lights shine really well, and it even works on tires and rims. I would suggest it, it works great. You can get it at a local parts shop. He I got it from lordco auto parts.
L8r,
Jason
'91 RS 305 5.0L V8
All stock for now...
Old May 3, 2001 | 08:24 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Will this work if you have faded front parking lamps? When I bought my car one of the parking lamps had been replaced so it looks like new but the other is original and its has a very cloudy finish on the front.
Poor college student(donations welcome ;0) with an all stock 1988 5.7L IROC-Z Hardtop, Auto. trans, white ext. w/gold accents (soon to be silver), black custom cloth interior, 4-wheel discs and G92 pkg. Car is dead stock. Has only standard Z28 power options and all the IROC performance stuff you could get. No pwr. seats, mirrors, or rear defrost.
Best run: 1/4 14.90 @ 92.7 MPH
See My Car here: http://zap.to/chevyguy1969
#3 Gone but shall never be forgotten. Long live the legacy of the man in black. RIP Dale Earnhardt "The Intimidator"
Old May 4, 2001 | 12:17 AM
johnyIROC's Avatar
After a bad tail-light painting experiment, I had to sand mine down.... and I polished them with aluminum polish... they shine like a *****
Old May 4, 2001 | 08:14 AM
nosaint's Avatar
Car: 1986 Trans Am
Meguiars #2 Polish
U wont believe the diff.
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
Nosaints Coolzone
Old May 8, 2001 | 03:21 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Yep... I agree..Meguiars#2 Polish works great on everything! Ive used it on the front parking lights,rear tail lights, console,clearcoated rims. Anything plastic or paint it will make it shine like glass. Just keep rubbing it on and taking it off till you get the desired effect. I even use it around the house to polish plastics.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old May 8, 2001 | 10:45 PM
Red Demon's Avatar
I put wax on mine.. and then I took a dremel and stuck a buffer on the end and went through all the little nooks and everything else.. Made them nice and purdy
fasteddi
Sep 10, 2015 09:32 AM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
