Engine compartment before/after
Old Oct 19, 2007 | 11:54 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, while i had the engine out, i decided to clean up the engine compartment.
Looked a little on the bad side.
During...
All finished up...
Re installed...
Sound clip...
Its not perfect, but keep in mind i rebuilt the engine, installed new heads and intake, cleaned and painted the engine bay and re installed it in 3 days.
Old Oct 19, 2007 | 12:22 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Engine compartment before/after
looks alot better. pretty stellar job for only a 3 day project.
what kind of paint did you use, and did you prep the surface rust any?
Old Oct 19, 2007 | 11:46 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
The paint was a rustolium(?) type, it is a can with the diamond plate look on it. Ill let you know when i find it. I cleaned any rust areas, sanded them with fint emory cloth, then hit the whole surface with scotch brite, then wiped it all down and blew it all down with a air nozzle. Still amazed with what i did in three days, i didnt even expect to have it done this far till next month, i also cleaned up the engine harness.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Firebird sweden
Aug 16, 2015 05:02 PM
Randomtask2
Aug 13, 2015 01:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
