Has anyone bough these headlights?
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
i was just wondering if anyone has tried these headlights from ebay and if so, how are they? I know most of these ebay kits are crap but these didnt look to bad. My stock lights just suck but I dont have too much cash for the expensive stuff. Or if anyone has found any other good kits. Anything would help. Thanks
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=016
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=002
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Re: Has anyone bough these headlights?
I bought this kit and the lights aren't bad at all! The only thing that sucked about them was having to alter the headlight buckets. I basically had to cut of the entire back of the stock buckets to make the lights fit correctly. Sounds like a pain but with a good set of tin snips it wasn't bad at all....
Overall not bad lights... Be aware though of the H4 Lights overpowering the circuit and blowing out your headlight switch. Summit sells an APC harness to fix this issue by connecting the lights up with relays and a connection to the battery itself.
Look around on the site and I'm sure you can find the threads with a quick search.
-Chris
-Chris
Engine: LS1, 5.3
Thanks man, I would love to see some pictures if you have any. Thanks
Car: 91 Camaro RS
Axle/Gears: 323
This is the best Image I could find of the headlights... Sorry for the slow reply...
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I put H4 headlights on my camaro and I really liked them. I ran them on both of my 3rd gens. Just make sure the ones you get have something in front of the bulb so you're not blinding oncoming traffic. The ones in the first ad look a little strange to me.
Will
Will
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
I originally bought e-bay versions, and have since switched to APC versions. The APC are better quality, have smaller boots, so need less modification. Definitely get a harness. They will brighten your lights even if you stay with stock bulbs. And they will save your headlamp switch if you do switch to H4's. APC and now painless make harnesses.
simz, you can also fab your own harness, pretty easily. All you need is a 30+ amp relay and fuse, as well as some assorted wire(14ga Red, 14ga black, etc). Wire the relay to use a direct battery source for power supply, with the fuse in the circuit, or use an existing high amperage fused circuit. Use the current headlight wiring to turn on the relay with the headlight switch, just cut the feed wires to the headlights and have them go to the relay activation circuit(labeled on the relay). Connect the relays ground to a good clean grounded surface(Rad support, etc), wire the relay to the other end of the headlight wiring you cut to get into the curcuit which is the same output to the headlights as stock, just now powered by the relay.
The relay only has two circuits, switched side and controlled side, almost all are labeled directly on the relay. You may already know this, but just in case.
With some patience and a little electrical knowledge you could get it done for about $15-20 or much less if you have some items around, like the relay, fuse, wire, etc.
The headlights are nice though, they are on my list once I find some time to get it done. haha
...Jim
W.E.D.
...Jim
W.E.D.
Car: 1985 Trans Am
Transmission: 700-R4
hey could you go into more detail on how to make your own harness? Id love to save money and not dish out $100+....
thanks!
thanks!
Celticsfan, You basically want to use the existing circuits to power on the relay you'll be installing, rather then the headlamps. For high beams do the same with a second relay using the wire feeds to the high beam lamps.
You'll be using the headlight switch to turn on the relay, which can handle more current then the switch can by itself. Run power and ground wires from the battery or high amperage battery powered circuits to the relays switched side. Run the headlamp switch wiring that was going to the headlamps to turn on the relay, with a ground on the other side of the relays control side/circuit.
Not sure if that makes more sense?
If I have a chance tomorrow at work i'll pull up a wiring diagram and get the wire colors for you to see if that helps more. I'll post it here in a day or two.
...Jim
W.E.D.
...Jim
W.E.D.
Car: 83 camaro, 91 rs convertible
Engine: 94 LT1, 355 tpi
Transmission: 4L60, 700r4
Axle/Gears: 373 posi
Here's something from the tech articles that talks about making an upgraded headlight wiring harness.
https://www.thirdgen.org/headlightupgrade
I'm about to convert mine to H4 using the ebay lights. We'll see how it works out.
Car: 1985 Trans Am
i wouldnt go with the ebay ones...
i'd get these http://store.summitracing.com/partde...5&autoview=sku
then the bulbs
http://www.motorbulbs.com/product_in...products_id/98
then the bulbs
Car: 1985 Trans Am
i found a harness on ebay
http://cgi.ebay.com/ebaymotors/NEW-A...QQcmdZViewItem
but its for 4 bulbs, i only need 2 for the bird...
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
i bought these lights for one of my camaros, but i like the projector clear lights better. you can fin them on ebay also.
