cowl size needed to clear RPM air-gap?
Old Jan 14, 2008 | 11:20 AM
imaking's Avatar
I am putting a new carb'd motor into camaro with an edelbrock air gap intake, standard base filter with 4" element. Is anybody else running the same setup or similar? How big cowl necessary to clear? Don't want to have to run a 6", will a 4" fit, 4 3/4"? Intake may "grow" a little more in the future with nitrous and possible spacer also. Thanks for any help guys
Old Jan 14, 2008 | 11:24 AM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
Re: cowl size needed to clear RPM air-gap?
I have a performer rpm manifold and 2 1/4 element with a 1 1/4" drop base and it barely clears the hood
Old Jan 14, 2008 | 11:34 AM
SteelTownMadDog's Avatar
I'm running the RPM with a 3" element, and 1.5" drop base, and I use to get minor rubbing from one of the ribs onder the hood until I took the peenball hammer to it. Now I get no rubbing, but it's that close. Here's what my setup use to be like last year; http://www.rbvracing.com/gallery2/ma...&g2_itemId=243
So, if you want to run a 4" element with a flat base, then you'll need a minimum of a 3" cowl, 4" would be better. If you run a 4" element with a 1" drop base, then a 3" cowl will be more than enough.
Old Jan 14, 2008 | 06:02 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I ran the same manifold + edelbrock carb with a 1.5" 3" tall air filter under the stock air gap hood. Now i have a 4" flat base, 3" cowl, the filter rubs a tiny but, but my cowl is also a bolt on.
Old Jan 14, 2008 | 09:07 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
You can barely clear it with a stock hood but I would recomend a 2 1/2'' cowl to compensate for engine movement that gave me a lil over an inch of clearence on my other camaro plus when I made the cowl functional my butt dyno told me the extra fresh air from the cowl made a difference
Old Jan 14, 2008 | 09:11 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Originally Posted by SteelTownMadDog
Hawt!
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
knight72
Aug 10, 2015 09:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
