Best tools / acccesories for Polishing Runners / intake (Appareance)
Subscribe
Jan 20, 2008 | 07:39 PM
hi guys i have the idea of polishing the runners (i already have polished plenum on my TPI System) and the intake manifold.-
i also have the aluminum heads.-
Its a 350 TPI that i want to make look real cool.-
im thinking about get myself a Dremel tool,is that necessary? or i just need sand paper ? which accesories do you reccomend ?
i already polished a set of 1989 Formula wheels and they are outstanding
but not my defy its to turn mirror like all the tpi system.-
any advices ?
its the dremel useful ?
any accesory for the dremel ? any extras? if its useful only ! thanx
Reply 0
Jan 20, 2008 | 07:45 PM
Re: Best tools / acccesories for Polishing Runners / intake (Appareance)
1/4" die grinder. Get a speed controller. Get a 6" and a 3" shaft (mandrel) for sanding rolls. Then buy a schwack of those, in different grits.
mcmaster.com is a good source
Reply 0
Jan 20, 2008 | 07:49 PM
thanx,yes i know different grits make the trick
for runners its wet sanding ? the same as wheels ?
thanx
btw ..is this dremel that a friend is selling me worth ?
Reply 0
Jan 20, 2008 | 07:57 PM
What does he want for that dremel kit? I think those go for around $80 here.
Unfortunately they don't have much power, you can stall it out easily, meaning you don't get to remove much metal very fast. Also those sanding drums are very expensive, once you start using it much. A 3 pack of sanding rolls costs something like $4 here, yet the thread on ones for a die grinder are closer to $.25 per.
If you're just touching up the outside to make it shiny and pretty (I guess this is the forum I stumbled into....) then the dremel would work ok. If you're going to be enlarging runners and porting heads, don't bother with a dremel, go straight to a die grinder.
Reply 0
Jan 20, 2008 | 08:45 PM
Yes,i will work outside only just for polish,i dont know and im not sure how much affects the performance porting the runners but ive read its better ported.-
can i polish the intake manifold too ?
Reply 0
Jan 20, 2008 | 09:41 PM
The dremel is great for tight spots. I think you will find that alot has to be done by hand and a die grinder.
Reply 0
Jan 21, 2008 | 04:27 PM
If you haven't actually grinded them yet-ACID wash cleans them em up. Then (though its coincedered wrong) silver high-heat spray paint-durable and you can use degreaser on the finish
Reply 0
Jan 21, 2008 | 05:23 PM
i sand blasted the runners
they are grey like on primer now
Reply 0
Jan 22, 2008 | 03:57 AM
Check the tech tips page....there is a article on this.
Reply 0
Jan 22, 2008 | 04:51 AM
Yep that's for the plenum,not the runners,my plenum its already polished
https://www.thirdgen.org/plenumpolish
thanx
Reply 0
Jan 22, 2008 | 08:42 PM
same deal with runners as the plenum. nothing different. alot more work. That's why I normally get all the dents out of the runners then somewhat enlarge them then just powdercoat them almost chrome.
Reply 0
Jan 22, 2008 | 08:47 PM
i want to polish instead of powdercoating them
they are complicated because they are rounded
i forgot the grit numbers ....
all wet sanding ? i think the first two are dry ...
any clue ?
thanx!
Reply 0
Jan 22, 2008 | 09:00 PM
depends on how good you want themcould go 220 on the heavily casted areas then 320 then 400 on all areas. then 400 wet and then 600 wet then polish. as hard as it is to get to all areas that is why I would go with powdercoating. the almost chrome is a very close match.
Reply 0
Jan 24, 2008 | 02:05 AM
how polished and shiny do you want it?...lol ive done motorcycle parts for years and its a pain in the ....... you get the idea. lol. what everyone else here is telling you to do will get you very happy results after all your hard work. i have polished stuff way beyond the point people posted hear and it sucks but it ends up looking like crome! me and my one friend did his zx10 and polished some stuff and cromed other stuff. took it to a show and people didnt believe the parts that were polished werent crome. for engine parts if its not a show car i would honestly powder coat it and be done with it. easier to keep nice with less effort and crome powdercoat looks very good. i couldnt give you an actual price for the powdercoat job on that but to give you an idea places will charge 50 to 80 bucks to powdercoat a motorcycle wheel so i cant see it costing alot at all to go with powdercoat
Reply 0
Subscribe
