Are these GTA rims????
Old Feb 1, 2008 | 12:18 AM
Jakout125's Avatar
Old Feb 1, 2008 | 12:30 AM
Stephen's Avatar
Car: 87 GTA
Re: Are these GTA rims????
Kinda hard to clearly make them out GOOD, but they not only appear to be GTA rims, but 87 only GTA rims. Which would also make sense with the center caps having 'birds, rather than the WS6 logos, as on the 88+ wheels.
Got a closer, more straight on pic?
Old Feb 1, 2008 | 12:56 AM
Jakout125's Avatar
I will have to get a a better pic, but it is 87 TA and the guy says there is a 350 TPI in it. So I'm not sure if it is a GTA or not I havent been able to look at the car personally only in pics thats why I was asking. Also, what is special about these rims "if" there only 87 gta rims. Thanks for your help!!!
Old Feb 1, 2008 | 12:57 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
they def 100% GTA rims. But the centre caps mean squat--can't tell if they are original to the rims.
Old Feb 1, 2008 | 01:25 AM
MNformula350's Avatar
NO, there were never any GTA specific wheels.
Those wheels were first available on 86 Trans Am's, then used on T/A's all the way through 92 (the GTA being a luxury model of the Trans Am) and also Formula's in 91-92.
So I do not know where they picked up the Slang GTA wheels.
Sorry for the rant, just a personal Pet Peeve.
Old Feb 1, 2008 | 07:13 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The gold center wheels were most commonly seen on GTAs, hence "GTA wheels". The domed high tech turbo wheels were the standard T/A (also on '87 Formulas) wheels and the crosslaced wheels were an upgrade until the domed wheels were dropped for the deep dish version found on the '88-92 Formulas. Also, most T/As had either black,silver, or charcoal centers and the GTAs had gold. I've also seen some T/As and GTAs with white and red centered wheels as well.
Old Feb 1, 2008 | 08:14 AM
Stephen's Avatar
Car: 87 GTA
The early crosslace wheels didn't have the "dimples" at the ends of the spokes, next to the polished lip. After 88, the dimples were introduced.
Here's a pic I took when I was showing my ride height. Notice the "dimples" at the ends of the crosslace. The early wheel were smooth & didn't have those in them.
Old Feb 1, 2008 | 12:44 PM
dinogta87's Avatar
Car: 87 Pontiac GTA, 03 Audi A4, 05 Volv
Engine: ZZ4 TPI
Axle/Gears: 9 Bolt, 3.27
Also - That does not appear to be a GTA, it seems to have vents in the front fenders, GTAs do not, looks like a TA. Also, if it is an 87 GTA, it will not have a 350 with T-Tops, the 350 motor in 87 was not available with T-tops, unless of course the owner had them installed afterwards.
Old Feb 1, 2008 | 01:02 PM
Stephen's Avatar
Car: 87 GTA
It's not a 87. It has the front bumper inserts, so it is an older body, or the nose was changed.
TAs could be had without the vents, but GTAs couldn't be had with them.
The sail panels don't have the GTA 'bird emblems, but those kinds of things are easily changed/removed.
But, it doesn't really matter. He was only asking about the wheels anyways.
Old Feb 1, 2008 | 01:47 PM
Jakout125's Avatar
Yeah the front was worked on, thats a different bumper, I believe the 82-84 style front bumper. Thanks for the tips about the rims.
Old Feb 1, 2008 | 02:38 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
well the rim ? is taking care of and as for the GTA ? look at the Rpo codes in the console and look for rpo y84. the GTA did not come with diff color G/X there are a lot of TA things on the car like the fenders, the seats, the ground X color. from what i see it not a GTA.
That should answer you question in your 2nd post.
Old Feb 4, 2008 | 08:48 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
It also looks like they have the fronts on the drivers side of the car, and the rears on the pass. side. The "dish" is different on front/rear "GTA" wheels. Same size wheels..just different offsets.
J.
Old Feb 4, 2008 | 09:17 AM
Stephen's Avatar
Car: 87 GTA
J.
Asa side note to that...Fronts can be run on the rear, but rears can't be run on the front. Well, they'll bolt up, and the car will roll...STRAIGHT forward and STRAIGHT backwards, just don't try to turn.
I had a body shop screw up putting mine back on years ago. When I tried to leave, I heard the rubbing & stopped. Left the car blocking the driveway, & made them take a floor jack out to the car, and switch them. They weren't very happy about doing it out there, without an air impact, but oh well! If they had done it right to begin with....
I'm currently tuning 4 fronts on my GTA right now, and have 4 fronts stored indoors & collecting dust.
Old Mar 19, 2008 | 03:16 AM
Spitzfiya's Avatar
doh' looks like i'll have to return my GTA! the factory screwed this one up!
"Y84" - GTA
"CC1" - T-Tops
"L98" - 350 TPI V8
"H" - 1987
Old Mar 19, 2008 | 08:07 AM
Roastedchicken's Avatar
Car: 89 TA
Engine: TPI 305
"Y84" - GTA
"CC1" - T-Tops
"L98" - 350 TPI V8
"H" - 1987
Did you change the color on that because WA 8555 is black.
Old Mar 19, 2008 | 11:30 AM
Spitzfiya's Avatar
Yup you can see it was black from the paint chipping off and the poor masking job by the previous owner.
But ehh heres some more proof.
According to Frankie (the Admin) from the GTA Source Page
Some Canadian-bound GTAs in 1987 had both the 5.7L engine and the CC1 hatch roof. I've not seen any US-spec GTAs with that combo for '87.
1987 - 5.0L cars = Yes ---- 5.7L cars = Canada only
1988 - 5.0L cars = Yes ---- 5.7L cars = No
1989 - 5.0L cars = Yes ---- 5.7L cars = Yes
1990 - 5.0L cars = Yes ---- 5.7L cars = No
1991 - 5.0L cars = Yes ---- 5.7L cars = No
1992 - 5.0L cars = Yes ---- 5.7L cars = No
Old Mar 19, 2008 | 02:53 PM
Car: 89 TA
Engine: TPI 305
Im a dope . I just realized GTAs didnt have the fender vents. I learn somethin new every day.
Old Mar 19, 2008 | 03:18 PM
Stephen's Avatar
Car: 87 GTA
Other 'birds could be had without the vents, but GTAs COULD NOT have them.
Old Mar 19, 2008 | 04:57 PM
Demon355's Avatar
Weren't the stock T/A wheels from '86 have a smaller dish then the GTA wheels?
Old Mar 19, 2008 | 05:15 PM
Stephen's Avatar
Car: 87 GTA
Sorta. There was a 15" crosslace used on Fieros. All TRUE 3rd gen crosslaces were 16", but I believe the lug patterns are the same.
The non-crosslace bird wheels were 15".
Old Mar 21, 2008 | 01:00 AM
Pocket's Avatar
Car: 91 Trans Am
Fieros use a 4.5" bolt pattern
They do not bolt up to Fbodys
The centercaps are much smaller
Various 91-92 base birds had a 15" crosslace
They are all gold and have a much shallower dish
Old Mar 21, 2008 | 01:18 AM
Pocket's Avatar
Car: 91 Trans Am
Pics are easier than words
Base bird and mid TA not to be confused with the Formula wheels
Colors, natural and gold
15x7
91-92 Base crosslace "Knockoff GTA"
Colors, powdercoat gold only
15x7
87-92 "GTA" wheels, found on GTAs and TAs
Note the dimples in the outside perimeter, 87 was the only year to not have these
Colors, gold, black, silver, gray, natural
16x8
Fiero stuff
Base/some GT
Colors, natural
14x6
GT Crosslace
Colors, black, graphite, natural
15x7
Hope that clears things up
Old Mar 21, 2008 | 01:37 AM
Stephen's Avatar
Car: 87 GTA
I stand corrected...I just always ***-umed the Fieros were the only 15" crosslaces, Only seen ine TA with 15" crosslaces, & that was just 2 years ago.
Old Mar 21, 2008 | 11:18 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
The 15X7 crosslace also came in plain old clear coated aluminum. I had a set on my car temporarily.
Old Mar 21, 2008 | 01:06 PM
Demon355's Avatar
Hmm, look different to me.
Old Mar 21, 2008 | 01:10 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
that cars not a GTA because it has vented fenders and GTA's came with solid fenders, UNLESS someone swapped them out
Old Mar 21, 2008 | 08:32 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Probably doesn't matter to anyone but, the fiero didn't use a 4.5" bolt pattern, nothing GM did actually. Many fwd's used a 5 on 115mm pattern (4.5" is 114.3). Anyway, fiero's used the 5 on 100mm pattern like the cavalier, sunbird, etc.
Sorry, it was bothering me
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
