Engine Bay Steam Clean f*&$!@ up!
Old Mar 12, 2008 | 11:23 AM
Oscar's Avatar
I'm partly venting and asking for some ideas.
So being as **** as I am, I had my engine bay steam cleaned. I primarily wanted the hard to reach areas to be cleaned. When I looked at my engine bay after the guy was done, . My heart just sank. I had a new A/C delco a/c compressor that had a nice finish, the cleaning took off the finish and left a blotching F!@#!^* ugly finish. Other metal components also had an ugly finish after. Some of the parts I know I can polish. The a/c compressor however I believe polishing won't do anything. I tried it and it didn't change anything. Does anybody have any ideas? Painting maybe? Any body else have a bad steam cleaning experience?
Old Mar 12, 2008 | 01:26 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Engine Bay Steam Clean f*&$!@ up!
What was the finish on it? Just a clear coat, or was it chrome or something...?
Old Mar 12, 2008 | 02:47 PM
Oscar's Avatar
It seems as if it could've been a very thin coat of paint. But it almost looked anodized. Color was almost like a black. See the attached pic. Now it looks more like acid fell on it and it is blotchy in appearance. sorry don't have a pic yet. geeze, if I had only know before.
Old Mar 12, 2008 | 04:45 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
What do you mean by polish? Did you try aluminum polish? I would think for sure that would do the trick. If nothing works, you can always wet sand with 2000 grit and then use aluminum polish.
Old Mar 12, 2008 | 06:50 PM
Oscar's Avatar
I used mothers polish but had no effect. The paint, stain, color, what ever it is seemed to be impregnated into the metal. So I think, you may be right about the wet sand.
Dam.
Thanks for the suggestion, I may have to do that.
Old Mar 13, 2008 | 03:15 PM
karl's-92'-z28's Avatar
Car: Too many cars
You can repaint it or buy a chrome shroud for it if you want that polished chrome look.
Old Mar 14, 2008 | 07:53 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
they said on motorweek the smaller steam particles can seep through wiring insulation and cause corrosion
Old Mar 17, 2008 | 08:26 PM
Mddhattr's Avatar
Ok I'm restoring the same type engine compartment. If you are trying to restore the black color. Do a good tape job and use a "good" rattle can. Rustoleum Semi Flat black be sure to clean with a good degreaser. As far as the aluminum, that part could be fixed with very fine steel wool. It will give a shiny but brushed look. The only thing to worry about with this is to watch the wire fibers. They have a tendency to go eveywhere.
Old Mar 19, 2008 | 03:11 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Where's the problem?
Old Mar 19, 2008 | 04:16 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Did you sign any kind of dis-claimer saying you wouldn't hold them responsible for any damages? Did they list anywhere how "safe" the chemicals they used are? Was it a professional business, or a kid down the street? I would be considering having them compensate for the damages.
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
