how do i adjust my foglights
Old Jun 13, 2001 | 09:19 PM
Stormshadow GTA's Avatar
they hang to low and my fog light bumoer holes are a little bit in the way.can i raise the fog lights somehow.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
"Three of the scariest letters you will ever see GTA"
Take a good look you won't see em for long
Old Jun 14, 2001 | 01:50 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
This is what i did on my 86...they are now in perfect alignment and do not move. First off, park about 6 or 7 feet away from a garage door, or the back of a rounded out car(like a C5 vette). Figure out which side needs adjustment, by turning on the foglamps, and how far up or down you want them. Now look at your foglamps after turning them off. You will need a phillips screwdriver. Both foglamps are in a bracket that is adjustable with a screw that is directly above each lamp in the middle...you might need to push part of the bumper out of the way to get to it thats by the foglight. But the screw is right over the foglamp, and its hard to get to and see. Depending on which way you turn it, it will either adjust the foglamp to shine higher, or lower. Mine are adjusted to bring out the full effect of power of my foglamps...they are adjusted high...so high, that i light up those interstate signs that are above the roadways on highways. Maybe it annoys drivers, but so do 18 wheelers that ride my @$$...when i hit the brakes suddenly, they fall back about half a mile good luck.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
[This message has been edited by PhantomTPI (edited June 13, 2001).]
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
