Installed pro-kit and KYB GRs's but car still sits same height ???
Old Jun 16, 2001 | 03:32 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Do i have to wait untill the springs and new shocks settle or somthing because the ride height hasnt changed at all, if so how long do i have to wait until they settle, what else can i do ?? Thanks a million
Old Jun 16, 2001 | 06:28 PM
Jza's Avatar
Jza
Well, unless your old springs were unusually tired, there should be an immediate half-inch drop at least. Of course, that's not an absolute... It'll settle over the course of about a month. If not, you may need to "clock" the springs in the insulators, or sometimes they don't get lined up into their pockets quite right. Check and make sure the springs are all well seated.
Old Jun 18, 2001 | 01:17 AM
wickedfbody's Avatar
I had the same parts and same problem on my car. It will take a few weeks to settle to its final drop height.
1991 Show Camaro in the works... to be back in from the painter in May or June.
[list][*]Super Ram 383[*]58mm TB[*]30 lbs Bosch injectors[*]Fast Burn Heads[*]Jet Hot Coated SLP 1 3/4" Headers[*]Midrange cam[*]Custom Prom[*]Global West SFC's with custom reinforcements[*]6 Point Custom Roll bar[*]ILE Brakes[*]Eibach Pro Kit springs[*]Polyuerethane Suspension bushings all around[*]ILE Aluminum Driveshaft[*]Full Autometer Instrumentation (10 guages)[*]Dupont custom pearl paint with flames and 6 ultra-thick clear coats [*]and the list goes on...[list]
Old Jun 18, 2001 | 08:48 AM
Pino91Formula's Avatar
You have to wait a godd three months or so ,,id say atleaste 6months , it took about that long for my car to settle
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
L98GTA87
Aug 5, 2015 11:02 PM
