anyone have LED brake and tail light. I want to see
Old May 10, 2008 | 08:54 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
I want to see some led brake and tail light pics if you have them. I see the price for them are around $10.99 for just a pack of 2 and I want to see if there worth it.
Old May 10, 2008 | 09:44 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Re: anyone have LED brake and tail light. I want to see
If your talking about the LED bulbs for the taillights, then no, its not worth it. They are not very bright and dont fill the housing with light.
Old May 10, 2008 | 10:05 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Check out this thread. cdoyle is in the process of doing a complete conversion, what he has so far looks great. cooltc2004 is right, the replacement "bulbs" are not bright enough and don't project far enough to be seen.
https://www.thirdgen.org/forums/body...nversions.html
Old May 10, 2008 | 11:08 PM
karl's-92'-z28's Avatar
Car: Too many cars
Here's my 3rd brake light
Old May 10, 2008 | 11:11 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
cdoyle's is a nice piece of work, you must check out that link above, i have kept up with his post since he made his front turn/parking's LED's and have loved to see the work
Old May 11, 2008 | 09:41 AM
Firebat's Avatar
The 4th gen style rear spoiler comes with an LED brake light, maybe 20-30 leds, something like that. Just another reason to get a 4th gen style spoiler
Old May 23, 2008 | 11:38 PM
VonKaiser's Avatar
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
https://www.thirdgen.org/forums/body...rsion-has.html
Actually if you get the right LED bulbs you can have superior light over anything else. You need to get bulbs that have a 270º light radius. Like this ones I got for my brake lights (red) and turn indicators (amber)...
24-LED 15mm Bayonet Based Bulbs
I'm in the process of converting my whole car to LEDs where applicable.
Old May 24, 2008 | 12:40 AM
Al Hasse's Avatar
I tried those LED replacement lights for a while and had to go back to the regular bulbs. They were only OK at night time, but you could hardly see them during the day, especially with the sun on them. For LED lights to be very effective in our tail light housings, they need to be right up next to the lens like cdoyle is doing in his conversion.
Old May 24, 2008 | 12:50 AM
Stephen's Avatar
Car: 87 GTA
My 01 Trans Am rear wing has standard bulbs, not LEDs...
Old May 27, 2008 | 02:17 PM
VonKaiser's Avatar
This is not entirely accurate. You can easily see my LEDs in the daylight. Again, you need to get the bulbs that shine back towards the reflective area inside the lens housing as well as forward. Mine are quite bright and they aren't even the brightest ones out there either. I posted what bulbs I use in my post above, 270º shining radius is enough to shine forward as well as back towards the relective area in the back of the lenses. Maybe you need to try some different bulbs?
Old May 27, 2008 | 02:33 PM
Al Hasse's Avatar
Not trying to discourage you or anything, but the one I used were the same as you linked in your other thread. Sure you could see them in the daytime, but get the sun on them and they just couldn't compete with the normal incandescent bulb. I had too many complaints that my tails and brakes weren't distinguishable from each other, especially in the daytime. It was a safety thing for me, but do what you want, it's your car...
Old May 27, 2008 | 05:18 PM
VonKaiser's Avatar
They work fine for me in the sun aka daylight. I'm not going to argue so I'll agree to disagree and move on.
Old May 27, 2008 | 06:06 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I agree with Al on this one. I tried those bulbs awhile ago in a couple different variations (upgrading when they started adding more and more LEDs) but they just couldn't compare to a standard incandescent when it came to illuminating the housing. Even with the LEDs faced towards the reflectors you had this "eye" in the center of the housing that most of the light emitted from.
Sucks too because I liked the instant-on and the deepness of the red they provided.
Old May 29, 2008 | 09:19 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Al or Ian, do you or anybody else have any picture so we can clear this up with our own opinions?
Old May 30, 2008 | 02:12 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
The only picture I have is this one.
Although it's missleading because of how long the exposure is. See how there's almost a beady eye in the center? That's really all you saw when you looked at it. The rest was just a slight hue. Pictures don't really give you a good idea on the light output unless you compared them in the same shot. I'll look around and see if I've still got the 36LED ones and pop one in to take a picture. Won't be till after this weekend though.
Old May 31, 2008 | 05:17 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
My idea for my 3rd gen stock spoiler 3rd brake light, is to polish the inside of the aluminum housing. maybe this would help for the LED's. and I'm using a group of LED's for the overhead light, the reg. bulb burns so hot it dryrotted the cover."my best assumption, after it crumbled upon removal."Polishing everything metal, maybe adding reflectors, and polishing the outsides of the housings "the plastic polishing tech on this site" Will this help any of you?
Old Jun 25, 2008 | 09:38 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have the "solid" one for my car, I still have the red lens, so it looks pretty much stock. His kits for the in spoiler Brake lights are awesome, and all his kits are pretty cheap.
http://members.aol.com/BlueTPI/3rdGen.html
dbrochard
Oct 3, 2015 12:43 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
