Which Enkei or BBS rim will fit under 91 trans am with 9" ford rear end
Old May 22, 2008 | 04:10 AM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
the rims should be 17" and under 7.5 kg
Lets talk about performance
Old May 22, 2008 | 09:02 AM
BuiltZ28's Avatar
Re: Which Enkei or BBS rim will fit under 91 trans am with 9" ford rear end
Let talk about the width of your rear end first.
Old May 22, 2008 | 09:51 AM
engongam's Avatar
Engine: 502 Ram Jet
As I mentioned in topic, it is 9" ford, 31 spline, 3.73 diff
Old May 22, 2008 | 10:15 AM
Stephen's Avatar
Car: 87 GTA
That tells WHAT it is, but not how WIDE.
Any rim will fit, if the backspacing is picked out correctly, which can be determined more by the width of the axle.
Gotta have the width to start with...
Old May 22, 2008 | 10:26 AM
engongam's Avatar
Engine: 502 Ram Jet
5/8”
The thing that confuse me is, when I give a full turn to the front wheel, will it rub the fender??
Old May 22, 2008 | 10:29 AM
Stephen's Avatar
Car: 87 GTA
A five eighth inch wide axle? Wow...This I've gotta see pics of...
Your REAR won't care about the FRONT...
Old May 22, 2008 | 10:36 AM
engongam's Avatar
Engine: 502 Ram Jet
http://www.moserengineering.com/Page...s-moserm9.html look at the compleate packages, I will but them and trying to find a suitable wheel for 14" disk brakes.
Any suggestions?
Old May 22, 2008 | 04:17 PM
BADNBLK's Avatar
COTM Editor
Your not going to put 14" brakes on the back end of that car???
What is needed is a measurement from the rear brake hub to rear brake hub, or you could tell us that it was ordered for factory width. Then you will get some better replies.
hectre13
Dec 11, 2023 08:14 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
