all red tail lights..
Old May 30, 2008 | 04:09 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
i have been seeing tailights on some third gens that are white/red/red/red instead of the original white/amber/red/red.. i have tried doing a search and cannot find a place that sells them.. can someone point me in the right direction?? THANKS!
Old May 30, 2008 | 04:45 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: all red tail lights..
most guys do it them self.
theres a few post on the subject look for "amber delete" or "taillights"
think you use testers candy red from hobby store and just paint of course there is some prep work to do but i cant remember off hand.
Old May 30, 2008 | 04:51 PM
sid rs91's Avatar
Transmission: wc T5
heres one
https://www.thirdgen.org/forums/auto...tail+red+light
Old May 30, 2008 | 06:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
A fellow member here (Stevo) did mine, painted mine on the inside.
Old Jun 2, 2008 | 08:55 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ok since im too lazy to go outside and look is the plastic amber all the way through?? Or in theory could i sand it down a bit then paint over it with a red? im assuming thats how steveo did krisb's but i can still see the amber a bit, is it noticable?
Old Jun 2, 2008 | 09:01 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Yes the amber color goes all the way through the lens. Most people, (including myself) tape off the light except for the amber, sand the area lightly and use a paint thinner type cleaner to clean the surface before painting it. I believe candy apple red from Testors is what everyone is using for the red. I then hit the whole light assembly with a coat of clear coat. (optional). Some will argue that painting the lens from the inside looks better, but thats just a matter of opinion.
Old Jun 3, 2008 | 07:58 AM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
i would like to do mine white then all black would that be possible/steet legal
Old Jun 3, 2008 | 03:26 PM
when you cleared over them did you use the same kind of clear coat that goes over base coat paint and use a paint gun.. or did you guys just spray bomb it?
Old Jun 3, 2008 | 04:14 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
since this is basically a do-it-yourself project I'm moving this to A&D where it is usually discussed and the information about it is better there, too.
Old Jun 3, 2008 | 04:48 PM
right on.. i just didn't know it was a do it yourself thing and not something that you could purchase.
Old Jun 3, 2008 | 05:14 PM
MNformula350's Avatar
I did mine on my 88 Camaro when I had it.
Then I took it a step further, and rewired them to come on with the tail lights, and still flash when signaling
Old Jun 3, 2008 | 06:25 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I used the matching testors clear coat spray paint.
Link to Red: http://www3.towerhobbies.com/cgi-bin...&I=LXHF97&P=FR
Link to Clear: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHE54&P=M
Old Jun 3, 2008 | 09:11 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I did it with my base bird lenses too. I used Testors translucent candy apple red model spray paint. I painted the inside of the lenses and the outside.
Old Jun 3, 2008 | 10:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
so if i clear coated it would that make them easier to polish? i want to do this mod so bad but im afraid its going to look like some 10yr old did it. I want to take a different set of lights and sand them down then shoot them with a red then clear coat, and if i can polish them up and if they turn out well they're going on lol
Old Jun 4, 2008 | 10:21 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
clear coat just adds a nice shine to the lights. after clear coat i gave them a buff and they turned out great. If you want to do the mod, TAKE YOUR TIME. Be very patient while painting/waiting for the paint to dry. If you rush this it will turn out bad.
Old Jun 4, 2008 | 02:31 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yeah which is why im buyin another set so i can do it right without having to worry wether or not ill have them back on the car in time, just out of curiosity/partial stupidity, what did you buff them with? and im assuming when you clear coat it you go over the entire lense? I would i need to sand the white light a bit then wouldnt i?
Linson
Oct 24, 2025 02:00 PM
Dragonsys
Sep 25, 2015 03:51 PM
