Painting.
Old Jun 5, 2008 | 11:54 PM
ThermalTrans's Avatar
Car: 85TransAm,97Firebird(Formula)
Engine: 305 5.0L,5.7LTI
Transmission: 700R4,Tremec 56
Painting.
I was wondering what methods you guys round here use for your paint jobs? I was thinking about using a 300-400grit sand paper to sand it clean(through all the paint) then spray it with urethane then clear coat. But I am really looking for others that did their own paint jobs.
Thanks guys,
Cristian
Old Jun 8, 2008 | 01:19 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Painting.
if you mean sand it clean by going all the way down to the bare metal then you need to put etching primer down on the bare metal. and also if you are planning on going all the way down to bare metal it would be a little easier to use paint stripper. then after etching primer high build then sand it with nothing coarser than about 600 or you will see sand scratches. also i would use some guide coat to make sure that you dont miss any little dings. what i did was strip my whole car to bare metal, etch primed it, bondo/metal glazed all dents and dings, high build primered it, sanded it with 220, high build again any places that sanded through and sanded it with 320, then sanded it with wet 600 grit with guide coat.
Old Jun 8, 2008 | 07:04 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Re: Painting.
why would you want to go all the way down to metal ?
If the car has no major flaws in it the a good scuff with
600 and then Base Coat-Clear Coat is used. No urethane then clear........go to www.autobodystore.com and in those forums you will find all the information you
want and need........
Old Jun 8, 2008 | 07:15 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: Painting.
y would i want to go all the way to the bare metal?.............because i wanted to, seems to be a good enough reason to me. if i spend all the money on supplies and all the time it takes to do it i want to be sure its gonna come out lookin pretty darn good. you never know whats beneath your paint unless you remove it. like the hack job i found under my paint. just a thought. i do paint and body work for a living myself at one of the biggest private owned shop in nc so i think i kinda have a clue what im doing.
Old Jun 8, 2008 | 07:59 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Re: Painting.
I was replying to Thermo-Trans and not you
so calm down and read what was written, If you
want to take your car down Bare Metal that
is your business, But I replied to the original poster.
Old Jun 8, 2008 | 08:22 PM
Car: 89 RS camaro
Transmission: th400
Axle/Gears: 4.11
Re: Painting.
oh ok sorry man, my fault its been a stressful day and im a little on edge right now. i apologize for being an idiot.
Old Jun 8, 2008 | 08:29 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Re: Painting.
Thank you for the apology and your not a idiot as I
have done that before, reply and felt like a fool.
It is all good, now rest up........
Old Jun 9, 2008 | 07:05 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: Painting.
depending on the age of the car....depends whether or not to go down to steel. If you have a 20 year old car...and want to repaint it...chances are, if you don't strip it...then your new material could blister...or lift...or a number of things. Especially...with the new products out today...applying those over the old school products...could cause major headaches.
Old Jun 9, 2008 | 09:48 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Painting.
when I repainted my Trans Am I went to bare metal, then sprayed a urethane primer. I took it to bare metal to prevent any problems such as what sickness mentioned, if your paint is lifting off or anything you should remove the paint because it will lift any new paint you put on top of it. and somebody mentioned etching primer for bare metal, this is a great idea because it bites into the metal and makes it waterproof also sealer will do this same thing.
as for what to put base coat over, I usually like to spray over 400 grit wet sanded.
SDIF
Mar 13, 2013 12:04 AM
T1m3_Sh1ft3r
Jan 21, 2010 02:44 AM
krismiller34
Sep 14, 2009 01:01 PM
chas0218
Aug 29, 2009 02:00 PM
