Color matching original paint?
Subscribe
Aug 6, 2008 | 04:02 AM
I still have the original paint on my Z28.. but the right side fender was replaced with a slightly discolored fender.. And its kinda annoying me.. Where could i get original color paint? I could take it to a shop but id like to do it myself.
Reply 0
Aug 6, 2008 | 08:04 PM
Re: Color matching original paint?
You can get the paint anywhere that sells automotive paint. You will need the paint code or some stores have scanners that will pick the correct color. The fender will need to be sanded first. Probably 500 or 600 wet would work best. You also will need to sand the adjacent panels with a grey scuff pad or 1000 grit paper. You just want to dull finish and get rid of the shine. Start spraying the base coat on the fender first. Once it's covered then start spraying into the adjacent panels a little further on each coat. When your'e done the color should blend evenly into the other panels. The basecoat will probably go about 1/2 into each panel. Then you will need to clear coat the panels.
Reply 0
Aug 11, 2008 | 07:08 PM
Quote: You can get the paint anywhere that sells automotive paint. You will need the paint code or some stores have scanners that will pick the correct color. The fender will need to be sanded first. Probably 500 or 600 wet would work best. You also will need to sand the adjacent panels with a grey scuff pad or 1000 grit paper. You just want to dull finish and get rid of the shine. Start spraying the base coat on the fender first. Once it's covered then start spraying into the adjacent panels a little further on each coat. When your'e done the color should blend evenly into the other panels. The basecoat will probably go about 1/2 into each panel. Then you will need to clear coat the panels.
1000 grit is way too high, thats not leaving any surface for the new paint to stick to. I'd use 400-600 grit for all the sanding. as for the paint matching I'd bring it to an automotive paint shop then have them match the paint with custom mixing.
I personally think trying to match the old beat up, faded paint will make it look worse but maybe your paint is in good condition.
Reply 0
Aug 11, 2008 | 07:15 PM
its not really beat up.. The paint actually looks very nice for 25 years old.. theres just like a few "bottom of soda can" sized faded spots here and there and would like to touch them up
How do i get my color code?
Reply 0
Aug 11, 2008 | 07:22 PM
go in your center console or rear locking compartment, there you'll find the rpo codes, run them through the decoder on this site and one of them will be your paint code.
Reply 0
Aug 11, 2008 | 07:29 PM
I didnt see anything in my console.. My trunk is jammed right now so i cant get into that.
Is there a chart anywhere that lists the colors used for the 1983 model Camaro?
Reply 0
Aug 11, 2008 | 09:07 PM
Quote: go in your center console or rear locking compartment, there you'll find the rpo codes, run them through the decoder on this site and one of them will be your paint code.
hey tmic he has an 83 They didn't have the rpos until 85 right?
Reply 0
Aug 11, 2008 | 09:16 PM
Quote: hey tmic he has an 83 They didn't have the rpos until 85 right?
hmm Im not actually sure, I just assumed that all third gens had rpo codes but you may be right.
in any case- blade, you can just take your car to a paint shop, they'll take a high quality pic of your paint and they'll mix paint to match.
edit: after a quick search it would appear rpo codes started in 84, so blade, your other option is to look for your build sheet.
sonymaster- thanks for correcting me, I would have never known lol
Reply 0
Aug 11, 2008 | 09:42 PM
Quote: hmm Im not actually sure, I just assumed that all third gens had rpo codes but you may be right.
lol no problem man. Its cool.
Reply 0
Aug 11, 2008 | 10:17 PM
being an 83 you should have a tag on the radiator support that says paint code
Reply 0
Subscribe
