FINALLY a 3rd Gen Project!
Old Sep 6, 2008 | 12:54 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I just started watching Horsepower TV on Spike and I was pleasantly surprised that their new project car is a 3rd gen! They're using a 92 RS with a 305 to make a good daily driver that's "easy" on gas and fun to drive.
Old Sep 6, 2008 | 01:02 PM
IrocZ'85's Avatar
Car: '85 IrocZ
Re: FINALLY a 3rd Gen Project!
i gotta see this, i like that show and it sounds like a good episode
Old Sep 6, 2008 | 01:22 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
I watched it today..just as hopefull for a huge build as you guys but fact of the matter is that I was pretty disappointed by the actual work that they did to the 305 TBI...the only improvement was 2 mpg 9hp and I believe 17 foot pounds of torque.. I was hoping that they would add some power adders or talk about a major swap..but anyways it was nice to see a thirdgen on tv
Old Sep 6, 2008 | 02:34 PM
IrocZ'85's Avatar
Car: '85 IrocZ
oh, that sux
Old Sep 6, 2008 | 11:54 PM
zeek's Avatar
Car: 1986 firebird trans am
that was only stage 1
there is still 2 more stages/episodes and $400 more dollars for them to spend in order to get better fuel milage and more power
Old Sep 7, 2008 | 02:28 AM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
sweet, good thing i have tivo because i dont want to wait for the 2nd airing tomorrow...well today.
Old Sep 7, 2008 | 09:55 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
What upgrade(s) did they do so far?
Old Sep 7, 2008 | 10:02 PM
custom cold air intake..relocated the battery to the back...replaced all fluids with full synthetic Royal Purple, lower thermostat I think...Throttle Body spacer...thats about it I think..they gained 9hp, 2.1 mpg, and 17 foot pounds of torque so far...there are still two more stages/episodes on this I believe...
Old Sep 7, 2008 | 10:04 PM
nut's Avatar
nut
Car: 88 Z28
Engine: Vortec 350, LT's
Axle/Gears: 2.73 posi.
Cold air intake, chip, tstat, tb spacer
^^ to late lol..
Old Sep 8, 2008 | 06:55 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
are the next two episodes on this weekend and the one after or are they going to space it out?
Old Sep 8, 2008 | 08:31 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
sweet going to DVR it. Horsepower TV Listings (Just Click)
Old Sep 8, 2008 | 08:51 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Can somebody tape this and post it up?
Old Sep 8, 2008 | 10:24 PM
IrocZ'85's Avatar
Car: '85 IrocZ
agreed, its impossible to find torrents for this show. I really wanna see it
Old Sep 9, 2008 | 10:05 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Did they state that their was a gain in relocating the battery to the back? Mine has been this way for a long time, but I did mine so that I could put the SLP CAI in its place. Did they do something similar ?
Old Sep 9, 2008 | 10:19 AM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
The reasoning behind the batt relocation (I believe) was so they would have a place outside the engine bay for the CAI filter.(drilled a hole in the battery tray) Its definately something I'd be willing to try before its all said and done. However the main reasoning for my hesitance is how hard would it be to jump the car off if ever needed....would make powering an amp much easier as there would be WAY less wire to run if mounted in trunk as well. Hmm... maybe I should think this out a bit more....
Old Sep 9, 2008 | 12:52 PM
AmorgetRS's Avatar
It also makes it illegal to run at NHRA tracks due to the rules where if you relocate the battery you need a battery cut off switch placed at the rear at the car. Makes it really a pain to relocate, and imho a bad idea in a car like that.
However, I have no idea what a Thirdgen on HorsepowerTV has to do with A&D so I am closing this thread.
bjpotter
Jan 22, 2019 12:27 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
neekolzun
Aug 24, 2015 04:59 PM
