91-92 firebird nose
91-92 firebird nose
I'm looking for a 91-92 nose for my black 90 formula. First, where can I find one? Second, what is involved to put it on? I know I need to relocate the front blinkers, but what else needs to be done? Thanks in advance?
THe nose you are looking for is very hard to find used, new, in canada, they run for about 1300 taxes in, i had to buy one for my 91. As far as installation, i am working this nose onto a 1986 TA right now, the only other mods that i had to do so far is cut the plastic honeycome that is in behind the nose, manufacture the metal nose mount bracket so that it was flat all across the top instead of indented for the older style nose, i also have to modify the ground effects a a little, post again if you have any more questions. check e-bay for the nose, a good wrecker might be able to find you one
