LED parking lights/side markers
Old Feb 19, 2009 | 06:25 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Do you guys what kind of LEDs would be perfect for Parking Lights/Sidemarkers without any problems?
Side Markers: #194 (4)
Front Directionals: #2057 (2)
Brake Lights: #2057(6)
Reverse Lights: #1156 (2)
License Plate: #194 (1)
2 Pin Electroinc Flasher
Old Feb 20, 2009 | 02:05 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: LED parking lights/side markers
www.superbrightleds.com
i got mine from there.....great bulbs.
Old Feb 20, 2009 | 05:34 AM
KITT1983's Avatar
ok this is the flasher I need: CF12ANL-01 http://www.superbrightleds.com/specs/CF12ANL-01.html
Old Feb 20, 2009 | 10:37 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
To make your side markers work correctly, you'll need to get their load resistors too. One for each side marker that doubles as a turn signal.
Old Feb 20, 2009 | 01:48 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Thanks for the website, they have all I need.
Old Feb 20, 2009 | 01:58 PM
KITT1983's Avatar
here are a few more
http://www.v-leds.com/
http://www.autolumination.com/
Old Feb 20, 2009 | 03:45 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
i bought 5xLED wide angle bulbs from superbrightleds.com for my side markers and license plate bulbs.Iinstalled them with no modifications whatsoever and they work perfectly fine. Just throwing that out there.
Old Feb 20, 2009 | 04:15 PM
KITT1983's Avatar
can you post a direct link to the led bulb you bought or a photo of it
Old Feb 20, 2009 | 10:54 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
here is a link to the bulb. it is the second drawing down labeled WLED-x5. I have the bulb in amber because I have clear side markers. If you have the factory amber side markers, buy the white bulbs.
http://superbrightleds.com/specs/bulb_specs.htm#x5
Old Feb 21, 2009 | 04:50 AM
KITT1983's Avatar
thanks for the help. Did you have turn signal problems such as the front turn signal and sidemarkers not blinking at all or when they feel like it?
Old Feb 21, 2009 | 04:14 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I only have the LEDs in my side markers. They blink just fine. I just have regular incandescent bulbs in my turn signals up front so can't help ya out there.
Old Feb 21, 2009 | 04:40 PM
KITT1983's Avatar
just to confirm this you are using the stock flashers with the leds
Old Feb 21, 2009 | 05:31 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Stock flasher. But as I said before I do not have LED bulbs in my turn signals up front. Just side markers.
Old Feb 21, 2009 | 05:43 PM
KITT1983's Avatar
thanks for you help
Old Feb 21, 2009 | 06:07 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
OR get an electronic flasher, not the thermal ones. Normal parts stores have them. I used to have th LED bulbs in every light on the car but they didn't put out enough light for me (this was 5 or so years ago when they were new and well under ~4 LEDs per bulb). I bought those resistors but then tried the electronic flasher (think trucks that tow trailers) and it worked great.
Old Feb 21, 2009 | 06:24 PM
KITT1983's Avatar
Tridon EL12 flasher is electronic. the Tridon EL12 for both trun signals and Hazard Warning lights
http://shop.advanceautoparts.com/web...PAMS_612723803___
Old Feb 21, 2009 | 06:40 PM
Stephen's Avatar
Car: 87 GTA
http://shop.advanceautoparts.com/Pro...pe=121&PTSet=A
Your link shows a mechanical flasher, not electronic.
Old Feb 21, 2009 | 06:55 PM
KITT1983's Avatar
it states electro-mechanical but I could be wrong
http://www.novitatech.com/tridon_daughter.html
Old Feb 21, 2009 | 07:25 PM
Stephen's Avatar
Car: 87 GTA
Yeah.....By MECHANICAL, I think it means it'll work on a thermal trigger, meaning it needs a load to heat up & move. Not 100" electronic/"digitally controlled".
My STS controllers are 100% electronic, no moving parts, to carry out the lighting sequence.
Old Feb 21, 2009 | 08:17 PM
KITT1983's Avatar
then do you know where we could get a decent led flasher
Old Feb 21, 2009 | 08:42 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
No. That is the same exact flasher I've had in my bird for 5 years. It's meant for older trucks that hook up to trailers with lights on them so that you still have your normal signal function with the added load of the extra lights. It doesn't rely on load at all light our stock flashers do. It may not be "digital" control but it isn't thermal. It'll work to control our signals if we run LEDs. And @ $13 not at all pricey.
Old Feb 22, 2009 | 10:02 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
"Electro-mechanical" doesn't mean much. A relay is an electro-mechanical part because it uses electricity and it has mechanical moving parts. If they mean that this flasher is electronic and contains a relay, that could be easily called electro-mechanical.
The only way to verify is to by one. Otherwise there's no telling what's in it from the name that's just a made up title by their marketing dpt.
Lou
Old Feb 22, 2009 | 10:13 AM
KITT1983's Avatar
Lou
I bought it Saturday from Advance Auto Parts and it says "Electronic Flasher"(Tridon EL12) on the package.
Old Feb 22, 2009 | 10:09 PM
loopingz's Avatar
There is a bunch of different lights inside my camaro. Does someone has a list of what size fits inside. For example in the trunk I have a rigid loop festoon bulb. But I dont know what I have without opening in the headliner '(festoon bulb but what length?), the vent control, the fog light control, the passenger foot place... If someone can help...
Old Feb 22, 2009 | 10:26 PM
Stephen's Avatar
Car: 87 GTA
Sylvania Bulb Replacement Guide
Old Feb 23, 2009 | 12:50 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I went to my local Autozone and bought l.e.d. side markers and brake lights and they work just fine. Didnt change a thing but the bulbs. They are twice as bright.
Old Feb 23, 2009 | 08:13 AM
loopingz's Avatar
Thanks, that rocks.
Old Feb 23, 2009 | 10:10 AM
ssean92's Avatar
Car: sold
I did the same thing and wasn't impressed. I VHTed my lights and thought they would be brighter but in reality they were lighter then the reg bulb?
Old Feb 24, 2009 | 12:32 AM
Car: 91 RS T-top
I dont see why not. While driving at night I couldnt see my side markers shining on the ground. Now I always notice them especially when they are blinking.
Old Feb 24, 2009 | 09:08 AM
loopingz's Avatar
I cant find the reference of the 2 lights that are in the center mirror. Can someone help me? Thanks
Old Feb 24, 2009 | 12:10 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
194 wedge type bulbs. i had to do minor modifications to get mine to fit however.
Old Mar 4, 2009 | 10:28 AM
KITT1983's Avatar
did you had to modify the side marker housing to make them fit
Old Mar 4, 2009 | 12:00 PM
loopingz's Avatar
I bought some different size of led. Some fits some others not. I installed two that fits! The only thing is that i have to put them by the exterior. It cannot fit from behind. Do you know where to get a proper "glass" for these small lights?
Old Mar 4, 2009 | 04:28 PM
KITT1983's Avatar
do you have photos of the lights you bought or any links?
Old Mar 9, 2009 | 01:38 PM
loopingz's Avatar
First sorry for the delay, I did an answer days ago but it did not went through.
I bought mine on http://www.superbrightleds.com/mini-wedge.html
So you can go find out the specs and pictures.
The WLED-X6 fit in the mirror and maybe in a bunch of place. The light is pretty fine for that place. Anyway I had to install the light by the front (I trashed the old piece of junkglass, if you know where to find one in good state, it would be cool), not from behind, like the old bulb could.
The WLED-X5 with its more beam do no fit (at least without turning the connector, but the LED would touch this way, which is not a good idea).
I put a WLED-X5 in passenger feet area and it is bright I like it.
I also tried some "festoon"
http://www.superbrightleds.com/festoon.html
The "Rigid Loop Festoon bulb with SMD LEDs" is fitting well in the trunk, but I did not tested it yet.
The 4410-X9 is the good size foor the headliner, the luminosity is not so bad but the beam is too much focused (30 degrees). This way the plastic cover do not show a uniform light, to be honest it is a bit disapointing. I bought this one because it is just drawing 1W, and I want to keep this area cool (I have burn trace around, normal lights are 5W, sometimes 3W. Remember Watts=Heat).
I would rather have bought the "4410-CWHP12" but I did not! 360beam a bunch of lumens but nearly 2W.
If I have to buy more lights there I will try this one. I can consider a trade with some of the lights I did not use. Contact if you are about to buy some lights there.
I still did not try to open the light on the ventilation commands, I will let you know, when I know what is fitting.
Old Mar 9, 2009 | 04:09 PM
KITT1983's Avatar
here is the led electronic flasher i bought
Old Mar 9, 2009 | 04:40 PM
KITT1983's Avatar
so the wledx5 can't fit into the side markers and the wledx6 can
I bought mine festoon led bulb off ebay (CTLumination http://stores.ebay.com/CTLumination) the bulb model number: #561
9 super bright Red leds into my dome light very Knight Rider
Old Mar 9, 2009 | 09:03 PM
loopingz's Avatar
I bought a red too! Didnt try it yet...
Old Jun 9, 2009 | 07:18 PM
KITT1983's Avatar
anyone replace the light in the center console?
Old Sep 25, 2009 | 06:12 PM
KITT1983's Avatar
http://www.youtube.com/watch?v=TorluvI-93I
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
