Projector retrofit inside(w/pics)
Old Apr 24, 2009 | 12:25 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If this belongs in the "fabrication" topic.Mods please move, if needed.Anyway,I started with escalade/jag/vette projectors.These are from a jag.Valeo brand, single xenon, 2.5dia,6 3/4 long,D1s style lamps.I taped over the side vents with some chrome duct tape.
Next, ebay "fake" projector 4656 headlamps.Most of it wont be used.
Cut back half for projector retrofit.Flanges glassed on.Made from a plain ol cardboard box.Cut to fit headlamp opening.Notice the two black lines/markers on the sides of the corrugated piece.These match the cutoff.Make them level on the headlamps for proper alignment of the projector.
Check for fitment issues
More to come.Should be done in a day or two
Old Apr 24, 2009 | 06:43 PM
AmorgetRS's Avatar
Re: Projector retrofit inside(w/pics)
Very cool project. How much are you going to have to cut the Camaro's light bar to fit those?
Old Apr 24, 2009 | 07:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, I wont have to cut anything on the car.At most i may need to enlarge the hole on the headlight bucket to accommodate the projectors.
Buckets cut to fit projectors.
Old Apr 24, 2009 | 10:58 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
how did you seperate the glass lens from the housing
Old Apr 25, 2009 | 10:59 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
That should look tight..
Old Apr 25, 2009 | 11:53 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Will that fiberglass be able to withstand the heat from the projectors?
Old Apr 26, 2009 | 12:15 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The ebay lamp housings are composite,lense is glass.Ive no doubt the fiberglass will hold.HIDs run cooler than incandescent bulbs, plus they'll have lots of ventilation
I used a x-acto knife to cut the adhesive.From both out & inside the housing.
Old Apr 26, 2009 | 08:21 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Wow, they look good. Can't wait to see some installed pics.
Old Apr 26, 2009 | 09:51 AM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
sweet man....i have some projectors layin around i was thinking the same thing....jus neva had the time to do it......but now i will......i already have hids in the iroc jus no projector....
Old Apr 26, 2009 | 10:09 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
wow cant wait to see them on the car
Old Apr 26, 2009 | 01:13 PM
Car: 1986 IROC-Z28
how was teh process of resealing them?
Old Apr 26, 2009 | 04:21 PM
Demon355's Avatar
Looks cool, waiting to see the final pics!
Old Apr 26, 2009 | 08:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Done,I will try a night time pic later on.
Headlight buckets.Left stock, Right modified.
Back view.
Old Apr 26, 2009 | 08:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I used liquid nails, but any adhesive thats bonds to glass should work fine.
Old Apr 26, 2009 | 09:48 PM
Charged350's Avatar
Car: 87 IROC Z28
i would get two more projectors and do the hi beams....even if you dont wire them in....or use the ebay fake projector ones in there....it will look better.....
Old Apr 26, 2009 | 09:49 PM
UDAMON's Avatar
Car: Mazda Protege5
looks great! nice work.
Old Apr 26, 2009 | 10:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I may do that in the near future.I also have two hi beam projectors i can try to fit.Ill wait & see though.Right now i like the way it looks.
Behind car, beam goes out 2 lanes from each side!
Old Apr 27, 2009 | 10:12 AM
Car: 1986 IROC-Z28
could u pm me with more info on where u got the projectors from...and the process of wiring them up?
Old Apr 27, 2009 | 11:04 AM
1Aauto's Avatar
Former Sponsor
Hey, that mod came out pretty cool.Good job.
Old Apr 27, 2009 | 11:07 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
wow... wanna help me do my car
Old Apr 27, 2009 | 11:11 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Im open for business.Seriously, PM me if your interested.
Old Apr 27, 2009 | 11:16 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
PM sent.
Old Apr 27, 2009 | 12:03 PM
bsporty's Avatar
Car: 85 Z28
Transmission: 5 speed
Very cool! I bought the same lights for my car.I had to return a set because the brackets that hold the projector on had popped off.
You did a really nice job with them!
Old Apr 27, 2009 | 12:18 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, cost around one bill(4-09).
Projectors $77
Fake proj $25
Adhesive $5
Paint $5
Additional mods: (11-10)
4 Halos $87
4 Shrouds $66
Hi-beam fake proj $26
I had the Xenarc kit prior,
but if needed.
DDM:basic kit $40
(not included)
D2S lamps $20
Adapters $20
Harness $20
Misc $20
Total:$411
Labor! dont ask!
Old Apr 27, 2009 | 11:30 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Looks great! I might have to try this, unless you're willing to sell some already done.
Old Apr 28, 2009 | 10:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Dont have any pre-built.Since Ive no idea what projectors one would like to use.Also just for labor Id say around $100!
Old Apr 29, 2009 | 07:27 AM
DBLTKE's Avatar
Engine: LB9, LB9
Where did you pick up the projectors and the housings up for so cheap? And was that including the bulbs? What did you do about the ballasts and the wiring?
Old Apr 29, 2009 | 02:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
ebay.Ballast/harness are on the bumper support.Bulbs came with the xenarcs.
Old May 3, 2009 | 05:59 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome skills dude
Old May 3, 2009 | 07:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Glad you like it.
Old May 3, 2009 | 08:03 PM
KITT1983's Avatar
sadly that would never fit my KARR I have H6052's. but I have Hella E-Codes
Old May 3, 2009 | 08:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Where there's a will there's a way.Maybe that that exact projector, but another.I put even bigger projectors in my triumph.The amount of space on that(or any) bike is smaller than most cars.
Old May 25, 2009 | 09:51 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
how much would you sell a premade set for? im actually very interested, ive always wanted projector for my car
Old May 25, 2009 | 10:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
PM sent
Old Jun 1, 2009 | 03:10 PM
cdoyle's Avatar
These looks really good, this is actually something I want to do someday.
Which cheapy projector housings did you use?
I've seen a few on ebay, did yours have the city light in it?
I don't really want it, and not sure if after I cut out the hole for the projector if it will still be there or not.
I would rather just get a housing that doesn't have them to start with.
could you send me a link to the ones you bought?
Old Jun 1, 2009 | 03:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
These are the lamps.His prices have gone up a bit.They have the city light, but that portion is eliminated when cutting the lamp for the projector mod.
http://cgi.ebay.com/ebaymotors/77-82...lenotsupported
Old Jun 1, 2009 | 04:18 PM
Car: 1987 IROC Z
$5 .... seriously ?
Old Jun 1, 2009 | 04:29 PM
cdoyle's Avatar
Originally Posted by omnipotentgoku
$5 .... seriously ?
plus $19 shipping lol
but that's about the same price as the ones I was looking at once you add in the shipping.
Old Jun 1, 2009 | 04:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Starting price was 1.99, BIN was 2.99, shipping is the same(ins req).I dont think he charged me tax either.
Old Jun 1, 2009 | 04:35 PM
cdoyle's Avatar
just got me a pair, this is something I've been wanting to do for awhile but I couldn't find 4x6 lights to do the retro.
Now need to find me some projectors.
Old Jun 1, 2009 | 04:41 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
For ebay, just go to "lighting & lamps" category.The type "projectors" in the search bar.You will get OEM projectors in the results.The other methods you will see TONS of aftermarket ****, plus hundreds of the fakes as well.
Old Jun 1, 2009 | 06:06 PM
  #42
Abubaca's Avatar
Good work on the fab. Always a fan of people custom making things they want when they're not available, or at least not at a good price.
...that being said though, and I know I'm in the minority, but I've felt no matter how much technology and R and D goes into it light, it's still just that. LIGHT. ...and short of blinding oncoming traffic, and being able to see ALL THE WAY TO YOUR DESTINATION.... ...there's no real need for "better" light.
Like I said, I know my opinion is in the minority, and it's just that, an opinion. Either way, nice work.
Old Jun 1, 2009 | 06:41 PM
  #43
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If your blinding traffic its more likely your lamps are NOT aimed properly.Projectors, well project light in the proper place.That combined with proper aiming of the headlights is better for everyone.No need to be driving around blinding oncoming traffic & thats my opinion!.
Old Jun 1, 2009 | 07:00 PM
  #44
cdoyle's Avatar
exactly!
Properly aimed HID projectors, is such an improvement over halogen sealed beam, there is no comparison really.
Like 1le said, if you're blinding other drivers, then they are not aimed properly. Quality projectors will have a cutoff, which keeps most of the light on the ground and out of the eyes of oncoming traffic. Some even have levelers built in too.
Old Jun 1, 2009 | 08:50 PM
  #45
Abubaca's Avatar
I've been driving for almost 20 years and have never had problems seeing where I was going at night.
Like I said though, it's all good and I admire the work. The mere fact that I even HAVE my Iroc is an exercise in desire, not necessity, so far be it for me to begrudge anyone for doing anything they want to do!!!
Old Jun 1, 2009 | 09:33 PM
  #46
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea i would of aggred with you a while back, but drive a car with real good headlights, it actually makes a huge diff, i never figured it, till i got a hold of a good set of headlights now headlights is my first up grade to any car/truck or whatnot i buy
Old Jun 4, 2009 | 01:13 PM
  #47
rocz's Avatar
Car: 88 IROC-Z 91 RS
Engine: 358 in the roc 305 in the rs
Transmission: 700's
is the lens glass on these lights
Old Jun 4, 2009 | 02:52 PM
  #48
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes
Old Jun 4, 2009 | 03:03 PM
  #49
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
wow I'm impressed. I think it turned out exceptional. Great work!
Old Oct 17, 2009 | 11:42 PM
  #50
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey Rick,
Nice work bro I would love a pair of these.
Tony.
